JST Posted March 12, 2008 Share Posted March 12, 2008 I know of some toyota axles sat around for a while now which i don't think the owner would miss. (or notice) trucks a bit of a mess and obviously doesn't intend to move for a while. Is it really worth the effort of getting them adapted to fit a 90 to replace std LR axles? i can get the fab work done for not alot and the axles would be free if i removed them just wondering if its worth the effort? What would i do ref props? Quote Link to comment Share on other sites More sharing options...
TJ101 Posted March 12, 2008 Share Posted March 12, 2008 If it was me,, I would use the Yota props as well, complete with the autobox, Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted March 12, 2008 Share Posted March 12, 2008 I know of some toyota axles sat around for a while now which i don't think the owner would miss. (or notice) trucks a bit of a mess and obviously doesn't intend to move for a while.Is it really worth the effort of getting them adapted to fit a 90 to replace std LR axles? i can get the fab work done for not alot and the axles would be free if i removed them just wondering if its worth the effort? What would i do ref props? Hasn't Nick got those axles under his truck? He could give you some idea as to whether it's worth it or not. Do you do the miles to warrant the work Quote Link to comment Share on other sites More sharing options...
lensen639 Posted March 12, 2008 Share Posted March 12, 2008 If you going to swap axles do it well and take volvos But I agree with TJ101 use the gearbox too. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted March 12, 2008 Share Posted March 12, 2008 Here's something for you James.... thought you might be having a touch of the vapours :lol: Quote Link to comment Share on other sites More sharing options...
landmannnn Posted March 12, 2008 Share Posted March 12, 2008 Very dependent on which Toyota axles. Also bear in mind that a well worn (sh&gged out) l/cruiser axle is only better than a l/r axle in a similar condition. Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted March 12, 2008 Share Posted March 12, 2008 What Toyota axles are you thinking? And what's your motivation? I'm currently fitting Landcruiser 80 series axles to my Discovery. Advantages are tougher shafts than LR, tougher diffs than LR, bigger brakes than LR, wider than LR (good with lift), lower ratio diffs than LR (good for fitting big tyres) and lockers as standard. LC 80 front axle on Discovery: Older Toyota Landcruiers and Hiluxs don't offer the same advantages as above - most don't have lockers, most have drum rear brakes and some have smaller diffs. Bear in mind there is a HUGE amount of work in stripping all of the brackets off and building new to suit the Landrover. Then there's custom props, or adaptors and custom brake plumbing. I wasn't concerned about all this work as I like doing it all myself and like you my axles were super cheap. If you're a bolt on man and paying some one to do the work, then it's not worth the cost compared to up-rating LR stuff. Quote Link to comment Share on other sites More sharing options...
pugwash Posted March 12, 2008 Share Posted March 12, 2008 Here's something for you James.... thought you might be having a touch of the vapours OH FFS this is getting silly you CANT have anyh of my axles- certainly NOT my vapour axles and definitely NOT my axles on my daily driver truck- although i admit it hasn't driven for a while! (Tim i'm really sorry- i'll get out there this week and do some more work!) Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted March 12, 2008 Share Posted March 12, 2008 James if you really do have access to some unloved yota axles then I would seriously grab them while you can. You say the owner won't miss them so offer him a couple of escudos and get welding. I have had a set of patrol axles on the floor of the workshop for 12 months or so and will eventually get round to fitting them. I guess even if you don't fit these for a couple of months it would be better to have them in storage than to leave them stuck in a yard somewhere to rust away through lack of use... Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted March 12, 2008 Share Posted March 12, 2008 I know of some toyota axles sat around for a while now which i don't think the owner would miss. (or notice) trucks a bit of a mess and obviously doesn't intend to move for a while.Is it really worth the effort of getting them adapted to fit a 90 to replace std LR axles? i can get the fab work done for not alot and the axles would be free if i removed them just wondering if its worth the effort? What would i do ref props? Is it worth it. Your truck hasn't seen daylight in weeks!!! Are you sure you still have a 90 in your barn or perhaps you now have a vapour 90 Quote Link to comment Share on other sites More sharing options...
Guest mortus Posted March 12, 2008 Share Posted March 12, 2008 are the axles of a patrol the best axles on yotas? what do you actually need to do to make them fit a landrover. Quote Link to comment Share on other sites More sharing options...
JST Posted March 13, 2008 Author Share Posted March 13, 2008 OH FFS this is getting silly you CANT have anyh of my axles- certainly NOT my vapour axles and definitely NOT my axles on my daily driver truck- why not? they arent doing anything and you have 4 of them, i'm off to get a trailer................ Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted March 13, 2008 Share Posted March 13, 2008 what do you actually need to do to make them fit a landrover. For LC series 80 (diffs are on correct side, as is steering): Cut off all of the existing brackets Make and fit all new brackets for shocks, springs, radius arms, a frame, panhard rod. Front prop adaptor / spacer Custom rear prop Brake line adaptors - for Disco to make from 5 line to 3 line, may not need anything on a 90. Wiring for the diff lockers New drag link Possibly new panhard rod, but i've used the LR one Maybe custom tie bar to clear the front radius arms, but I've used a 3 link, so it's different for me New wheels obviously! So, a stroll in the park really Mind you I will end up with equivelent of about £3000 of LR axles for less than £500 and a good few weekends. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 13, 2008 Share Posted March 13, 2008 are the axles of a patrol the best axles on yotas?what do you actually need to do to make them fit a landrover. Not unless you get them from a Nissan Mo Quote Link to comment Share on other sites More sharing options...
pugwash Posted March 13, 2008 Share Posted March 13, 2008 why not? they arent doing anything and you have 4 of them, i'm off to get a trailer................ what would you do with them? it's not as if your vehicle gets any more use than mine does! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted March 13, 2008 Share Posted March 13, 2008 <br />what would you do with them? it's not as if your vehicle gets any more use than mine does!<br /><br /><br /><br />And that's saying something. Cos yours is in bits and James truck is.....?! Quote Link to comment Share on other sites More sharing options...
lensen639 Posted March 13, 2008 Share Posted March 13, 2008 Are Landcruiser 80 series axles easy to find? The quality is good, but I heard that spares are hard to find and expensive too. Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted March 13, 2008 Share Posted March 13, 2008 They're not that easy to find - that's why JST should 'borrow' Pugwash's when he's not looking Service bits are easy to find - Milner 4x4, though things like brake parts are MUCH more expensive than LR (how about £90 for a pair of discs) More complicated bits like shafts, CVs and diffs is more of a problem, the best bet seems to be the US or Aus. Though I was averaging 1 diff every 3 months with my standard LR axles before going to LC and now I hope I wont need any! Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted March 13, 2008 Share Posted March 13, 2008 James, You're a bad, bad man ............. watch out or Jim will send the 'boys' around............ You would be better off picking up the MOG axles from the other pile of scrap ................... I'll take the engine ............. Ian Quote Link to comment Share on other sites More sharing options...
TJ101 Posted March 13, 2008 Share Posted March 13, 2008 ................... I'll take the engine ............. Ian Toooo late Ian,, engine already bagged !!! Besides you already have a good engine Quote Link to comment Share on other sites More sharing options...
JST Posted March 13, 2008 Author Share Posted March 13, 2008 James,You're a bad, bad man ............. watch out or Jim will send the 'boys' around............ You would be better off picking up the MOG axles from the other pile of scrap ................... I'll take the engine ............. Ian Toooo late Ian,, engine already bagged !!! Besides you already have a good engine Tim - engine now with Bryan, dropped it off this pm on way back through Now got 2 sets of axles! Mog ones already have the brackets there - very well made so can sell on the LC ones now. Not sure what to do with this gearbox thing, looks expensive got to be worth £50 talking of £50 i gave Viridor a call and they are going to pop in tomorrow to collect the carcass Tim, i have already paid them to take it away, i offered it to the guys but no one wanted it. Are for you Mr Walford, i think your find my trucks been out more than yours this year! off road that is, you know wet muddy stuff, i will send you some to remind you. Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted March 13, 2008 Share Posted March 13, 2008 Is the Toyota box auto or manual? What year was it from? Paul Quote Link to comment Share on other sites More sharing options...
marek Posted August 19, 2008 Share Posted August 19, 2008 fitting toyota axles is a rubbish idea if u like changeing diffs every wk end Quote Link to comment Share on other sites More sharing options...
discojmz Posted August 20, 2008 Share Posted August 20, 2008 fitting toyota axles is a rubbish idea if u like changeing diffs every wk end but a great idea if you dont? Quote Link to comment Share on other sites More sharing options...
pugwash Posted August 20, 2008 Share Posted August 20, 2008 fitting toyota axles is a rubbish idea if u like changeing diffs every wk end ummm great first post lol have you ever taken apart the diff from an 80 series and compared it to a rear rover item? Quote Link to comment Share on other sites More sharing options...
