FIP setup
JST
Any recommendations for a firm that specialises in the FIP setups, or for refurbing injectors? (60k miles, 200tdi def)
Mine has started using alot more fuel than normal and smokes (black) alot when labouring after standstill
eg coasting to a near stop at a jct then pulling away in 2nd whilst still rolling = quite a bit of black smoke.
struggles to hold higher speeds as well, more so than used to.
impg also about 21 down from 26 avg. so something def up.
any recommendation or checks i could do?
It sounds like your fueling's out. Sound VERY simerlar to what happened to my winch bi*ch's Tdi Golf. Basicly the bottom end bearings went allowing the crank to wobble about ant the cam belt to skip a couple of teeth. When was the cam belt last done? I've heard of the belts on 200s rotting and then loosing their teeth.
these from Yell.com
Taunton --- I used 'fuel imjection' for this result
Chris White Engineering
Unit 1, Hugo St, Taunton, Somerset TA1 1
Tel: 01823 332943
used diesl injection for these below ---------------
Exeter
Electro-Diesel (RCJ) Ltd
4 Goshawk Units, Osprey Rd, Sowton Industrial Estate, Exeter, Devon EX2 7JG
Tel: 01392 208090
Cowick Fuel Injection Services
18 Norman Court, Budlake Rd, Marsh Barton, Exeter, Devon EX2 8PY
Tel: 01392 276664
Honiton
Diesel Injection Services (Devon) Ltd
Reme Drive, Heathpark Industrial Estate, Honiton, Devon EX14 1SE
Tel: 01404 47919
I've a good one in Helston, but their over 100miles from you. :D
Edited by western
Ralph,
many thanks i will give them a ring mon see how far i get.
Will - i am hoping not, LR serviced and cam belt changed 20k ago (3yrs)
Si - a little to far i feel!
Thanks for the responses guys.
There is a place in Ex Eat ERR pm for the number of a bloke who knows - or find it yourself
Bugger Tim, as always has beaten me to it...
It's because I am having a wake - by myself
