Tonk Posted December 6, 2005 Share Posted December 6, 2005 wot do people use to paint their rollcages with? lookin for summat that can be brushed on, sticks like sh!t to a blanket and is fast dryin. i realise that no paint ill withstand rubbing on trees though Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted December 6, 2005 Share Posted December 6, 2005 wot do people use to paint their rollcages with? lookin for summat that can be brushed on, sticks like sh!t to a blanket and is fast dryin. i realise that no paint ill withstand rubbing on trees though NOT Hammerite! I've got it on my chassis and I thoroughly regret going to the effort, its SO brittle, I hardly need to tap it for a bit to flake off and that's with the correct primer. Al. Quote Link to comment Share on other sites More sharing options...
pugwash Posted December 6, 2005 Share Posted December 6, 2005 wot do people use to paint their rollcages with? lookin for summat that can be brushed on, sticks like sh!t to a blanket and is fast dryin. i realise that no paint ill withstand rubbing on trees though Properly prepped and applied POR15 is extremely good but expensive mind. I POR'd my chassis and had huge difficulties sand blasting it off as it was so sticky. If you don't prep the metal exactly like they tell you to then you will have adhesive problems mind! Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 6, 2005 Author Share Posted December 6, 2005 roll cage tube comes red oxided as standard, would POR15 stick to that? Quote Link to comment Share on other sites More sharing options...
Mark90 Posted December 6, 2005 Share Posted December 6, 2005 I've had good results with Jenolite satin black coach enamel, and also with a Dacrylate 'chassis black'. It doesn't actually say chassis black on the tin, can't remember what it does say though I find the Dacrylate paints tend to give good results and are hard wearing. POR15 only sticks to rusty surfaces, clean metal or pre-painted surfaces and it will just peel off. Quote Link to comment Share on other sites More sharing options...
Hillbilly Rebel Posted December 6, 2005 Share Posted December 6, 2005 You told me you were gonna paint it BLUE!!!!! Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 6, 2005 Author Share Posted December 6, 2005 well i aint gettin it chromed Quote Link to comment Share on other sites More sharing options...
Hillbilly Rebel Posted December 6, 2005 Share Posted December 6, 2005 So you haven't denied your NOT getting it done "BLUE" then!!!!! Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 6, 2005 Author Share Posted December 6, 2005 it will be black like last one, preferably semi gloss Quote Link to comment Share on other sites More sharing options...
Hillbilly Rebel Posted December 6, 2005 Share Posted December 6, 2005 is that bluey black or black with a hint of blue??? Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 6, 2005 Author Share Posted December 6, 2005 just completely blick Quote Link to comment Share on other sites More sharing options...
Jon White Posted December 6, 2005 Share Posted December 6, 2005 I used hammerite "straight to rust" paint for mine, and its not come off yet, and its been graunched against trees and all sorts! in satin black....... Jon Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted December 6, 2005 Share Posted December 6, 2005 I'm looking at more full-on industrial coatings like Dupont Imron. Some kind of epoxy or polyurethane paint. I'd use Protecta-Kote but you can't get it without the little crushed up bits of rubber in (for grip). I really like that stuff and it's properly tough, but painting a landy with bobbly paint would look, well... odd. The stuff I had on my steel hulled boat was amazingly tough - 2 pack epoxy. You could drive the 10 tonne boat into / along a rock or bit of concrete and the paint would still be there. Try that with hammerite... Al. Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted December 6, 2005 Share Posted December 6, 2005 teflon coat it so that it slides on the trees better Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 6, 2005 Author Share Posted December 6, 2005 or just grease the trees Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 6, 2005 Share Posted December 6, 2005 Techloid from KCC 01420 475303 tractor paint, its good and cheap and you can get LR colours in it, 1 litre tins about £8 ? You might even find a baby roller would work, then the "Finish" would match ! Nige Quote Link to comment Share on other sites More sharing options...
Guest mr_wuffles Posted December 6, 2005 Share Posted December 6, 2005 Black Friars QD90 (even comes in Land Rover Green) Paul (of blackpig fame) swears by it as well. Quote Link to comment Share on other sites More sharing options...
