jcwcooper Posted April 22, 2008 Share Posted April 22, 2008 Right I decided a while back I was going to enter the mind boggling world of Winches. I have a winch bumper fitted and the next stage is a Split Charge, Im looking into the cheaper options of using the X-Charge or T-max. These both have different ways of going about their jobs not that i understand them particually. The X-Charge used a HD relay, Are there any advantages or disadvantages of this system i should be aware of? Im not expecting it to be perfect at £40 Second up is the T-Max system this uses a solenoid and also has a display, Has anyone got this system, is it any good......advantages/disadvantages? Anyone recomend either of the systems? Next up is a 2nd battery, Ive just bought a Optima Red top and im not terribly impressed with it although it does work. Has anyone used Exides or deka intimedators? Is it worth using a deep cycle for the winch? I Have quite a few things running on my current battery....Twin Fans, Spot lights, Amplifier and someones fitted an air horn in the past so that comes off the battery too I also intend to fit 4 lights on a light bar. Should I run things like the lights off the AUX battery? or just the Winch. I Have decided on buying either a Superwinch EP9 or a Comeup/GoodWinch DS9.5/TDS9.5 I would like to move the solenoid pack to the wing, I understand you need to use thicker cable if you are mounting it further away so it does not loose power is this correct? Also How do you go about attaching the handset to the solenoid pack if its tucked away? Thanks for any help in advance Dave. Quote Link to comment Share on other sites More sharing options...
Orange Posted April 22, 2008 Share Posted April 22, 2008 The split charge system I can't help much with other than to say that plenty of people are running the X-Charge without issues... Mounting the winch solenoids up in the wing is a good plan and something I will be looking into. The bigger the cable the better, IMO, but I am no sparky!!! As for plugging the handset in, either hard wire an internal control to the cab (I used a bit of 3-core rubberised flex cable and a switch from David Bowyer - at Goodwinch), or remove the socket from the solenoid box, extend the wires and mount it somewhere more convenient. You could even do both for those occasions when you are respooling the rope on your own... HTH Adrian Quote Link to comment Share on other sites More sharing options...
white90 Posted April 22, 2008 Share Posted April 22, 2008 socket for winch on headlamp panel solenoid remotely mounted Batteries connected in parallel Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted April 22, 2008 Author Share Posted April 22, 2008 what batteries are they. Dave. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 22, 2008 Share Posted April 22, 2008 FIAMM 096. Used to be sold by a motorfactors in Minehead. They had so many returns they stopped selling them. Last time I was there they had a pallet load sat at the back of the workshop . Tony has had no problems with his and I think JST is running the same set up also without problems. Quote Link to comment Share on other sites More sharing options...
white90 Posted April 22, 2008 Share Posted April 22, 2008 And Exmoorcop/Nick walker then TJ101/ mine are as you can see from 03 and 04 and have been faultless supplied from Mole Valley Farmers Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 22, 2008 Share Posted April 22, 2008 I only had 1 fitted and killed that, when it went back under warrenty I recieved another make in return. Didn't seem keen on doing it but did in the end. When I killed my other battery from there they twisted and turned and refused to change under warrenty. As it was costing me a lot in fuel to go and see them everytime it was easier and cheaper to buy a new battery Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted April 22, 2008 Share Posted April 22, 2008 my Battery is the same age as Tony's and came from MVF .................. no problems so far................ I guess it all boils down to the fact that squaddies cant be trusted with anything ............... its real hard to make stuff squaddie proof Ian Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 22, 2008 Share Posted April 22, 2008 Ian Told you before. Easier to do mine clearance than veh electrics Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted April 22, 2008 Share Posted April 22, 2008 Dave, why do you think you need two batteries and a split charge? Quote Link to comment Share on other sites More sharing options...
western Posted April 22, 2008 Share Posted April 22, 2008 I run 2 x PC1700 Odyseey batteries feed by a 100amp alternator via LR's own split charge relay system, my albright solenoids are fitted in a similar place to white90's on the front left inner wheel arch & 2 remote sockets above each headlight & a Lodar radio remote system. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 22, 2008 Share Posted April 22, 2008 IanTold you before. Easier to do mine clearance than veh electrics Who put that there?? That was some time ago. It's now a tasteful blue. I had more hair then and I'm not so grumpy nowadays Quote Link to comment Share on other sites More sharing options...
pugwash Posted April 22, 2008 Share Posted April 22, 2008 I'm not so grumpy nowadays Jeez you must have been bad in the past Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 22, 2008 Share Posted April 22, 2008 That was some time ago. It's now a tasteful blue. I had more hair then and I'm not so grumpy nowadays You recon,, see Jim beat me to it !! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 23, 2008 Share Posted April 23, 2008 Thanks for the vote of support! That's what I like about this place the great mates you have Quote Link to comment Share on other sites More sharing options...
roguevogue Posted April 24, 2008 Share Posted April 24, 2008 At the weekend I took part in the Howlin Wolf challenge round 2, which was a great event. B) The event was held on one of the most consistently steep sites that I have been to, lots of winching in long runs. On at least one punch I spooled out the whole cable then back in and out and back in again, the most sustained winching I have ever done. I used both front and rear winches at the same time. I had no charging issues at all, running an X-Eng split charge coupled to one of their new Numax batteries. I should declare that I am sponsored by X-Eng, that doesn't change the performance though! Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 24, 2008 Share Posted April 24, 2008 At the weekend I took part in the Howlin Wolf challenge round 2, which was a great event. B) The event was held on one of the most consistently steep sites that I have been to, lots of winching in long runs. On at least one punch I spooled out the whole cable then back in and out and back in again, the most sustained winching I have ever done. I used both front and rear winches at the same time. I had no charging issues at all, running an X-Eng split charge coupled to one of their new Numax batteries. I should declare that I am sponsored by X-Eng, that doesn't change the performance though! I'd be interested in more on the Numax battery. I'm thinking of ordering one to run my fridge. It's one of the sealed marine ones XV27MF a 100 amp if I remember. mike Quote Link to comment Share on other sites More sharing options...
simonr Posted April 24, 2008 Share Posted April 24, 2008 It's an 86Ah, sealed wet-cell battery. There is a 105Ah version but with lower current - and it doesn't fit in a Defender battery tray! This is from the same series as that, just pitched more at the 4x4 market than marine. Si Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted April 25, 2008 Share Posted April 25, 2008 Dear jcwcooper (Dave) It's good to have members with genuine questions which are of interest to other members. To gauge the effectiveness of LR4x4 please take a few moments to complete the Customer Satisfaction Survey. We look forward to you using us again! Thank you for using the LR 4x4 knowledge base. Do you recall your recent contact with LR 4x4? Yes No Thinking about your most recent contact, how would you rate the members ability to help you or to get you to someone who could help you? Would you say … Excellent Very Good Good Fair Poor How would you rate the members overall knowledge of your problem or question? Would you say … Excellent Very Good Good Fair Poor And how would you rate the members on being courteous? Would you say … Excellent Very Good Good Fair Poor How would you rate the members on helpfulness, in other words, a willingness to assist you? Would you say … Excellent Very Good Good Fair Poor How would you rate the members on being able to help you resolve your issue/need? Would you say … Excellent Very Good Good Fair Poor Now let's talk about LR 4x4 as a forum. How would you rate LR 4x4 on the length of time it took to find a qualified representative? Excellent Very Good Good Fair Poor Thinking specifically of the International Forum, how would you rate your overall experience during your last contact with them? Excellent Very Good Good Fair Poor Thank you for your time, I assure you it was well spent. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 25, 2008 Share Posted April 25, 2008 It's an 86Ah, sealed wet-cell battery.There is a 105Ah version but with lower current - and it doesn't fit in a Defender battery tray! This is from the same series as that, just pitched more at the 4x4 market than marine. Si Yes Si it's the 105 I'm getting. It's the same size as the Elecsol I'm taking out. The battery try is getting removed and a staright sided and bottom one is being fitted.... mike ps. I've been offered it at 70 quid ..Delivered. Is that a good price ? Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted April 25, 2008 Author Share Posted April 25, 2008 Thanks for your replys guys. very Helpfull.........The battery from X-eng seems very well priced, and if their other products I have are anything to go by i wont be disappointed. Ta. Dave. Quote Link to comment Share on other sites More sharing options...
