jimmy_neutron Posted June 17, 2008 Share Posted June 17, 2008 was gonna get alloys for my 1991 defender but its cos its got drum brakes on the back, it started looking expensive. Then noticed people like craddocks selling quite a nice looking modular wheel. Are they any good ? Do they start rusting away after 10 seconds of use ? Any got a pic to show me what they look like on a defender ? Ta Quote Link to comment Share on other sites More sharing options...
mirkop82 Posted June 17, 2008 Share Posted June 17, 2008 I'm using a set of 8x16 modular rims manufactured by Mangels and I found it pretty good, also seeing the price of it. No, the paint (in mine) seems to be resistant to maltreatment I've attached two pic of me and my friend Oriano's 90 (but the one near his Def/Pub is me) Quote Link to comment Share on other sites More sharing options...
ozzie1989 Posted June 17, 2008 Share Posted June 17, 2008 A lot of people use Modular or Eight Spoke wheels, they are apparently strong and last well. My friend had a set on his old Defender that stayed there for at least 7 or 8 years before he sold it and I think they're still on it now. Only damage was from off-road abuse, scratches etc. I did think about putting a black set on my silver Defender at one point but decided to stick with the alloys for now Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 18, 2008 Share Posted June 18, 2008 Here's mine with 8x15 silver modulars and 33x13.50-15 Maxxis Mudzillas, just used them for the first time and they are brilliant :) Quote Link to comment Share on other sites More sharing options...
pist0nbr0ke Posted June 18, 2008 Share Posted June 18, 2008 hi there, It may be worth you reading the topic on Craddocks, might be good looking else where- in my opinion. Cheers Neil Quote Link to comment Share on other sites More sharing options...
Michele Posted June 18, 2008 Share Posted June 18, 2008 and 33x13.50-15 Maxxis Mudzillas, just used them for the first time and they are brilliant :) and you're still able to steer Stephen? Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted June 18, 2008 Share Posted June 18, 2008 the modulars from craddocks are like 8 quid more expensive than at paddocks! a helpful hint to help with modulars, is, there the inner wheel bit is welded to the outer rim bit, you put a bead of silicon, because that seam is a mega water trap so fill it will silicon soon as you get them! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 18, 2008 Share Posted June 18, 2008 and you're still able to steer Stephen? Yep - just what the doctor ordered for down here Quote Link to comment Share on other sites More sharing options...
Young bobtail Rhys Posted June 18, 2008 Share Posted June 18, 2008 My modulars after a little bit of modifying............. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted June 23, 2008 Author Share Posted June 23, 2008 My modulars after a little bit of modifying............. Thanx all.... Bought em from silverline 4x4. Bloke i spoke to gave excellent advice and seemed to know what he was on about. Got Pirelli Scorpians on the rims and they are actually much better than i expected, but time will tell as they get worn in. Cheapest i could find as well Mrs nearly killed me.... need to find a better way of smuggling parts in for my next project. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted June 23, 2008 Share Posted June 23, 2008 re the sneaking of parts.... I find that a separate credit card and a friend with a farm a few miles away works wonders... Managed to sneak a whole engine into the truck earlier this year ! Neil Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted June 23, 2008 Share Posted June 23, 2008 Here's mine with 8x15 silver modulars and 33x13.50-15 Maxxis Mudzillas, just used them for the first time and they are brilliant :) Normally those are on 10 x 15 to give enough offset to give a decent turning circle ........................ but I guess you must have specified 8 x 15 as your don't protrude 2 - 3 inches outside the eyebrows like mine do Absolutely brilliant tyre ................ road manners are a little strange & interesting , but once off the black top their performance is much better than I expected them to be ...............I guess its a combination of low ground pressure and an agri style tread............. Ian Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 23, 2008 Share Posted June 23, 2008 Yes if you run 10x15 on unsurfaced clay roads, visibility out the side windows isn't even optional It isn't great with 8x15 but it does keep the spray down a bit. They do just rub on the arms on full lock but not too bad, better than my old BFGs I think. Front end view here http://forums.lr4x4.com/index.php?showtopi...20&start=20 Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted June 23, 2008 Author Share Posted June 23, 2008 Yes if you run 10x15 on unsurfaced clay roads, visibility out the side windows isn't even optional It isn't great with 8x15 but it does keep the spray down a bit. They do just rub on the arms on full lock but not too bad, better than my old BFGs I think. Front end view here http://forums.lr4x4.com/index.php?showtopi...20&start=20 Nice I got 7x16's on with 235/85's. seems to sit slightly higher than the standard 7.5x16 but it can't do really. Don't seem to rub at all. Quote Link to comment Share on other sites More sharing options...
Def V8 90 Posted July 13, 2011 Share Posted July 13, 2011 I'm on 35/12.5 KL71s, 10x15 mods, good lock, no complaints other than small children want to take it home as a Tonka truck!! G PS Anyone know whether paddock & craddock 10x15s same offset? I need a spare and price better with paddock!! g Quote Link to comment Share on other sites More sharing options...
Tom1809 Posted July 14, 2011 Share Posted July 14, 2011 My 90 with 8x16 modulars just painted them black as they where originally silver Tom Quote Link to comment Share on other sites More sharing options...
SPendrey Posted July 14, 2011 Share Posted July 14, 2011 Hmmm, putting two pieces of 2"x2" on the ground might not be the best security measure to protect your vehicle. Although, if it is an auto that'll probably stop if being stolen backwards at least! Quote Link to comment Share on other sites More sharing options...
Tom1809 Posted July 14, 2011 Share Posted July 14, 2011 Ah that's 2 4x4 fence posts , I'm just lazy and can't be arsed to cut the grass. Quote Link to comment Share on other sites More sharing options...
