old leafer Posted July 16, 2008 Share Posted July 16, 2008 ok i suspect my erg has gone if i get a blanking plate i take it it goes between the turbo inlet and pipe ? and when in place can i strip the rest if anyone has done it any chance of a pic regards mark Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted July 16, 2008 Share Posted July 16, 2008 Assuming a 300TDi and EGR EGR blanking plate Replacement top intercooler hose HTH Pete Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 17, 2008 Share Posted July 17, 2008 You don't want to remove your ergs 'cos your Disco won't go with no power to push it along Quote Link to comment Share on other sites More sharing options...
old leafer Posted July 17, 2008 Author Share Posted July 17, 2008 Assuming a 300TDi and EGR EGR blanking plate Replacement top intercooler hose HTH Pete thanx mate i new somone would no what i ment lol Quote Link to comment Share on other sites More sharing options...
auf_wiedersehen_pet Posted July 17, 2008 Share Posted July 17, 2008 Assuming a 300TDi and EGR EGR blanking plate Replacement top intercooler hose HTH Pete Snap.............. HTH Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted July 17, 2008 Share Posted July 17, 2008 You don't want to remove your ergs 'cos your Disco won't go with no power to push it along I thought the same but kept quiet because I didn't want anyone thinking me a geek for knowing what an erg is... D'OH! Quote Link to comment Share on other sites More sharing options...
auf_wiedersehen_pet Posted July 17, 2008 Share Posted July 17, 2008 I thought the same but kept quiet because I didn't want anyone thinking me a geek for knowing what an erg is...D'OH! If you are a geek for knowing what a ERG is then what does it make me when I have no idea at all? Go on then................... Quote Link to comment Share on other sites More sharing options...
western Posted July 17, 2008 Share Posted July 17, 2008 You can amaze or bore all your friends now what's a Erg Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted July 17, 2008 Share Posted July 17, 2008 If you are a geek for knowing what a ERG is then what does it make me when I have no idea at all?Go on then................... It makes you one of the 99.9% majority.. To be honest I don't think I have heard 'erg' mentioned since I left school 35 years ago! But if I recall correctly it is a ridiculously small unit of work - like about 10-6 joules or something... Just checked and it's 10-7. .. That's a tenth of a millionth of a Joule, and a Joule is about a quarter of a calorie and there are over three hundred calories in a Mars bar - as I said, ridiculously small... HTH Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 18, 2008 Share Posted July 18, 2008 According to Google, an erg can also be a sand dune. Now you definitely don't want one of those in your Disco Quote Link to comment Share on other sites More sharing options...
jason69er Posted July 19, 2008 Share Posted July 19, 2008 Good afternoon chaps and chapesses,yes it's political correctness day i'm affraid.Sorry,but i think we've got too make the effort once in a while.Anyway cutting to the chase can anyone steer me in the right direction in obtaining a egr blanking kit with the hose please ie,paddocks,craddocks etc as i'm not being successful in my search.Many thanks Quote Link to comment Share on other sites More sharing options...
drkwack Posted July 20, 2008 Share Posted July 20, 2008 My turn to be stupid, but isn't there a load of vacuum pipes nd wires to remove as well or do you leave these in place?????? Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted July 20, 2008 Share Posted July 20, 2008 Good afternoon chaps and chapesses,yes it's political correctness day i'm affraid.Sorry,but i think we've got too make the effort once in a while.Anyway cutting to the chase can anyone steer me in the right direction in obtaining a egr blanking kit with the hose please ie,paddocks,craddocks etc as i'm not being successful in my search.Many thanks I got my blanking plate from Fleabay for a couple of quid and the silicone hose's from allard motors also via Fleabay. My turn to be stupid, but isn't there a load of vacuum pipes nd wires to remove as well or do you leave these in place?????? Yes, there are some other bits to remove, a solenoid valve and some tubing and wiring. You will also need to block the pipe from the vacuum pump to the solenoid valve. Quote Link to comment Share on other sites More sharing options...
Richard Mills Posted July 20, 2008 Share Posted July 20, 2008 Hi There , I just blanked off the EGR on my Disco. It was easy and simple. Just leave everything there, but where the output from the EGR joins the inlet pipe, I just used the gasket to draw around and cut a shim from an old can. Inserting this in there stops the gas circulating and renders the EGR valve out of service. 10 Minute fix. Quote Link to comment Share on other sites More sharing options...
