gelf Posted January 9, 2006 Share Posted January 9, 2006 ive got long travel suspension with loads of articulation....... which has been great until i needed change the rear wheel, with only a hi-lift to do it.......DOH! who makes checking straps then?... other than scrapiron. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 9, 2006 Share Posted January 9, 2006 M&M sell them, big yellow ad in the usual comics. Or use Gwyn Lewis 'challenge' spec dislocation cones with the hook then just slot a bit of bar through to stop the spring dropping out. Might not be explining this very well but it works, just ask RobHybrid. Quote Link to comment Share on other sites More sharing options...
gelf Posted January 9, 2006 Author Share Posted January 9, 2006 i have the G Lewis set up.......... and now you say it......i know what you mean. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted January 9, 2006 Share Posted January 9, 2006 go to breakers, cut off some seat belts - get mrs busy with a sewing machine - sorted Quote Link to comment Share on other sites More sharing options...
robhybrid Posted January 9, 2006 Share Posted January 9, 2006 Just keep a spare pice of round bar (the size of a 1/2" drive tee bar) fit it between the coils of your springs and through your Gwyn lewis dislocation/relocators and as you jack up the spring via bottom spring clamp will lift up the axle. You can end up holding the wheel higher up than jacking a std 90. Your bottom spring clamp needs to be in good condition too. Quote Link to comment Share on other sites More sharing options...
simonr Posted January 9, 2006 Share Posted January 9, 2006 I used to have a bolt welded by the head to the top spring hanger and another to the axle. Just use a length of chain to connect together by pushing a link over the shank of each bolt. I like Gwyn's solution though. Si Quote Link to comment Share on other sites More sharing options...
Jon White Posted January 9, 2006 Share Posted January 9, 2006 Chop off spring mounts and fit parabolics - end of problem!!! Quote Link to comment Share on other sites More sharing options...
SteveG Posted January 9, 2006 Share Posted January 9, 2006 Why not just carry a small bolttle jack too for lifting the axle. Problem solved without fitting check straps. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Tonk Posted January 9, 2006 Share Posted January 9, 2006 just dont change wheels Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 9, 2006 Share Posted January 9, 2006 Why not just carry a small bolttle jack too for lifting the axle. Problem solved without fitting check straps.Cheers Steve OK for wheel changing on a 'clean' road, but what if stuck up to axles in mud and want to lift the wheel to slip a waffle under? Quote Link to comment Share on other sites More sharing options...
dollythelw Posted January 9, 2006 Share Posted January 9, 2006 I use a lift mate on a hi-lift to get waffles under, less scrabbling around especially if the car is half buried in slop Quote Link to comment Share on other sites More sharing options...
