ciderman Posted August 23, 2008 Share Posted August 23, 2008 Ok ,After a bit of thinking I was considering fitting and Autobox to my 200tdi challenge truck , So what are the pros and cons over a manual box ?? And whats going to be a suitable box to source for this task ? Jase Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 23, 2008 Share Posted August 23, 2008 Firstly, you'll have to find a 200TDi autobox. Not many around. Second, you'll have to move the engine forwards 6" to accommodate the length of the box. either that or end up with a teeny rear (custom) prop. Say goodbye to engine braking. Say goodbye to burning clutch smells. If you want to have a drive of one, wait a couple of weeks and have a go in mine.... once I' ve finished the bu99er! Off road I love the autobox. For challenge events it is great as you can match wheel speed to winch speed and left foot brake when required for inch perfect positioning etc. Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted August 23, 2008 Share Posted August 23, 2008 Nothing to do with me, but Disco 200 TDi automatic,L reg (I think).Had lots of new parts fitted by mechanic owner,tax and MOT. £700. QUICK SALE NEEDED. DONT ASK ME ANYTHING,I AM ONLY THE MESSENGER. RING MIKE ON.07972 609134. It was posted on another forum I use. Paul Quote Link to comment Share on other sites More sharing options...
Hamish Grundy Posted August 23, 2008 Share Posted August 23, 2008 hi, im not 100% sure but couldnt you use a auto box from a 300? and change the back plate and flywheel?? or fit a 300tdi and box complete? im biulding a 300tdi auto 80 coiler at the moment, when i test drove it in the disco i loved it, you can go as slow as you want and floor it and it picks as well as my v8....well almost with a little tweaking!! hamish Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 23, 2008 Share Posted August 23, 2008 Jase, its a good way to go - I loved the 2.8 + auto. Much better than manual and more reliable. The problem is finding a 200tdi auto. The hard part to find is the engine backplate as a lot of the other bits are interchangable with 300tdi auto bits which are much more readily available. Length may be your issue which will make a mess of your weight distribution. TBH if this disco doesn't work out for you it may almost be worth getting hold of a 300tdi + auto as it means you can swap in the entire engine and gearbox assembly and save a lot of mucking about. Quote Link to comment Share on other sites More sharing options...
jericho Posted August 24, 2008 Share Posted August 24, 2008 im biulding a 300tdi auto 80 coiler at the momenthamish can you show us some pics of the engine and box in the chassis? I would put an auto in my 2a if I thought it would fit ok. Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 24, 2008 Share Posted August 24, 2008 Tdi plus auto in an 80" will be very tight for space! The engine in my 90 was well over the front axle and the rear prop wasn't overly long anyway. Take 13" out of it and it would be tiny! Quote Link to comment Share on other sites More sharing options...
JST Posted August 24, 2008 Share Posted August 24, 2008 Jase, not think the auto would suck the power too much as well? i think td5 auto if your going to go to the trouble. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 24, 2008 Share Posted August 24, 2008 I love the control of my 300/auto, altho it's a V8 box. I haven't seen a big change in engine braking, altho the fuel economy got much worse. My box uses an adaptor plate to mount to the engine. The block's quite far back in the bay but I think it uses standard props. How long is a standard 300 install from the handbrake drum to the nose of the crank? Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 27, 2008 Author Share Posted August 27, 2008 Ok then , I have almost sourced a 300 box with any assoiated bits from a disco ,Will mentioned the engine back plate , So will the 300 plate fit on my 200 lump . And I want to make sure I take everything I need from the doner disco ,so can any one tell me exactly what just in case i miss anything , coz its a long drive to get it . Thanks Jase Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 27, 2008 Share Posted August 27, 2008 So will the 300 plate fit on my 200 From my research, no. The 200Tdi has the rear oil seal in the rear housing whereas the 300Tdi has it in the back of the block. You will have to find a 200Tdi rear housing/adapter. IMHO, probably easier to fit a 300Tdi and sell the 200 on. Chris Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 27, 2008 Share Posted August 27, 2008 Ok then , I have almost sourced a 300 box with any assoiated bits from a disco ,Will mentioned the engine back plate , So will the 300 plate fit on my 200 lump . And I want to make sure I take everything I need from the doner disco ,so can any one tell me exactly what just in case i miss anything , coz its a long drive to get it . Thanks Jase As Chris said you really need a 300tdi backplate with the integral crank oil seal. These simply can't be found for love or money. I know of someone who's modified a 300 backplate to fit a 200 but it was a hassle and took a bit of time. As it happens I do have a 300tdi auto backplate kicking about if you're interested. I've been meaning to call Ashcrofts to see if they'd like it but I hadn't got round to it. If you do decide to go down that route drop me a line.... Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 27, 2008 Author Share Posted August 27, 2008 Does it look like this one Will http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...A:IT&ih=008 Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted August 27, 2008 Share Posted August 27, 2008 Auto bhox is 660cm long, Your LT77 is 500cm long! Spect you can guess why I know that! Im keeping the motor where it is in mine and taking everything else(including the rear axle) back. its nose heavy enough without moving the motor forward. Quote Link to comment Share on other sites More sharing options...
white90 Posted August 27, 2008 Share Posted August 27, 2008 The 200TDI backplate is available from L/R direct under the classic parts scheme DO NOT BELIEVE the "These simply can't be found for love or money" Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 27, 2008 Author Share Posted August 27, 2008 Thanks Tony , Dont spose you have a link do you ? Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 27, 2008 Author Share Posted August 27, 2008 Auto bhox is 660cm long, Your LT77 is 500cm long! Spect you can guess why I know that! Im keeping the motor where it is in mine and taking everything else(including the rear axle) back. its nose heavy enough without moving the motor forward. Now theres a strange phenomenon You been reading my study notes again Steve Quote Link to comment Share on other sites More sharing options...
white90 Posted August 27, 2008 Share Posted August 27, 2008 No link Jase just give L/R a call and ask for the 200TDI auto backplate from the Classic parts list A bloke on another forum dispelled this "not available myth" Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 27, 2008 Share Posted August 27, 2008 Does it look like this one Will http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...A:IT&ih=008 That's the chap - bloody good price too! Tony, I'll believe it when I see one. I went through all this a little while ago when I autoed the tgv. There was an intermittent supply of new 300 tdi auto backplates retailing at about £230 IIRC however, from speaking to several people who tried to do 200 conversions they couldn't get hold of backplates: Ashcrofts rarely had them, they almost never come up second hand due to the number produced and LR couldn't supply them new EVEN THOUGH THEY LISTED THEM. If this has changed then its great news but I can't believe they put it back into production to produce tiny numbers. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 28, 2008 Share Posted August 28, 2008 Now, I put all this together on my 300Tdi, and I remember it was different somehow for the rear oil seal. There were dowels and seals but I misremember how it all worked. I do remember being fortunate that there were two dowel holes in the block that I needed, even though they hadn't been used for the OEM backplate. Re-reading that, it sounds like I've got a 200Tdi back end on a 300Tdi block. I'm sorry Jase, I don't love you enough to pull the engine or box out to have a closer look Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 28, 2008 Author Share Posted August 28, 2008 Looks like its going to be a complete 300 engine and box ,to lessen any further complications .Its going to be a xmas project as I guess its going to need a whole new driving style and theres going to be a few cock footed moments Cheers all for the advice Jase Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 28, 2008 Share Posted August 28, 2008 Jase - you'll love it. Awesome setup! Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 28, 2008 Share Posted August 28, 2008 Yeah, if you're like Will you'll love it enough to strip it to its component parts and forget what it's like to drive Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 28, 2008 Author Share Posted August 28, 2008 I guess im gonna have to cable tie my left leg to the handbrake then to stop me heading for the screen . Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 28, 2008 Share Posted August 28, 2008 It's weird actually. All the buses at work are auto so I'm used to swapping 2 pedals for 3 and back again. The only time I've used the "clutch" since going auto was in an emergency stop (bluddy cyclists) and it's very odd when your foot just falls through the place where you're hoping to find a pedal Car still stops though, so it's all safe and legal. Unless you fit a wider pedal from a RR or somesuch, you won't hit the brake with your left foot accidentally. Quote Link to comment Share on other sites More sharing options...
