Les Henson Posted October 18, 2008 Share Posted October 18, 2008 The TD engine is 87bhp and no intercooler. The TDi's are 115bhp and intercooled, which is why they are so powerful in comparison. Les. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted October 18, 2008 Share Posted October 18, 2008 ... the diesel used in RR late 80's which I have forgotten the engine name and wasn't a LR unit anyway? You are presumably recalling the 2.4 (?) VM diesel. By all accounts this is probably best forgotten, or left to other 4WD manufacturers. Quote Link to comment Share on other sites More sharing options...
western Posted October 18, 2008 Share Posted October 18, 2008 So whats the big difference between a 2.5TD and 200 TDi and why leave out the 'i' on the 2.5TD?Presumably the 200 TDi was the first Diesel to be used on RR or Disco 1 apart from the diesel used in RR late 80's which I have forgotten the engine name and wasn't a LR unit anyway? Big difference is the TD was indirect injection & the Tdi's are Direct injection, makes hell of a difference on bhp/torque & driveability TD = Turbo Diesel Tdi = Turbocharged Direct Injection the Tdi was a big leap forward in small [sub 3 litre] direct injection diesel engines for LR & most other manufacturers soon latched on as the way to go. Quote Link to comment Share on other sites More sharing options...
nas90 Posted October 18, 2008 Share Posted October 18, 2008 Thanks chaps, just curious. Quote Link to comment Share on other sites More sharing options...
The Badger Posted October 19, 2008 Share Posted October 19, 2008 not sure if this is of any use, but im taking appart a 110 2.5 TD right now, so if you need any parts give me a PM? Engine was running really well after a 70 mile drive from where I brought it. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted October 19, 2008 Share Posted October 19, 2008 The Tdi cylinder head is also alloy and the combustion chambers are in the piston crowns. Very little is interchangeable between the engines except the tappet slides and rollers. (Found this out when buying bits for a 2.25 3 bearing diesel being reconditioned). Quote Link to comment Share on other sites More sharing options...
poohbear Posted October 20, 2008 Author Share Posted October 20, 2008 thanks Badger - I've cut my losses and swapped a spare lump that I had in the garage - took me all day though what with swapping various bits and bobs from one to another! Just got timing belt to do tonight and can then re-plumb and away she goes, I hope D. Quote Link to comment Share on other sites More sharing options...
FridaT Posted October 20, 2008 Share Posted October 20, 2008 Oops! looks pretty bad The pistons are AE, which I think are not original items, so they may have been replaced previously. Standard size still and the top of the bore doesn't appear to be badly lipped. If that's the case, then just new piston kits, head gasket, and some RTV sealant and it's all back together and running. Make sure your cooling system is in good order - this problem is usually caused by over heating. Les. Turbo diesel original equipment pistons are AE Hepolite. Cracket pistons are due to combustion problems caused by overheating and/or faulty fuel injection equipment. FridaT Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 21, 2008 Share Posted October 21, 2008 Thanks Frida - I thought AE were after-market suppliers only. Les. Quote Link to comment Share on other sites More sharing options...
FridaT Posted October 21, 2008 Share Posted October 21, 2008 Turbo diesel original equipment pistons are AE Hepolite. Cracket pistons are due to combustion problems caused by overheating and/or faulty fuel injection equipment. FridaT AE are original equipment piston supplier for: 2.25 petrol & diesel 2.5 petrol, diesel & TD V8 engines There probably are a few more but the engine type would not be part of our range. FridaT www.turner-engineering.co.uk Quote Link to comment Share on other sites More sharing options...
wozza35 Posted October 21, 2008 Share Posted October 21, 2008 I could of made them pistons,i would not recommend AE anymore after seeing their quality control after moving to poland Quote Link to comment Share on other sites More sharing options...
