Cat_J Posted October 17, 2008 Share Posted October 17, 2008 Had a play with the wiring this lunchtime and took the rear door card off and can't see the problem with it. So I took the switch out the front and couldn't see a problem there either. Without taking the dash apart (as seems to be becoming a regular occurrence) Is there anywhere else I should check too? Rear window is now unusable in the mornings as its cold now. Ooo, actually need to check the fusebox but last time I checked that it was intact and still not working. I wiring loom for the rear lights and back door runs under the car and I don't particularly want to go picking at it. Quote Link to comment Share on other sites More sharing options...
Madcowz Posted October 17, 2008 Share Posted October 17, 2008 Have you checked the voltage sensing relay behind the dash? There is a tech thread on this one. This is what was causing mine to not work. http://forums.lr4x4.com/index.php?showtopic=194 Now I just need to repaint the elements on the window as I only have 3 working. And what with the high back seats and tyre on the door, I can't see anything behind me. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 17, 2008 Share Posted October 17, 2008 The VSR was dicky on mine too and removing it as per the tech article got mine working. Apparently these VSRs are hideously expensive from Land Rover ! Mo Quote Link to comment Share on other sites More sharing options...
Cat_J Posted October 17, 2008 Author Share Posted October 17, 2008 I'll have a play around later, seems like a good way to go. How much are Land Rover ripping us off for this one then? Quote Link to comment Share on other sites More sharing options...
Jonathan Posted October 17, 2008 Share Posted October 17, 2008 My heated Rear Window works fine as long as I don't have the head lights on and the Heater. As soon as II put One or the Other on the heated Rear window stops working I need to look at my VSR Quote Link to comment Share on other sites More sharing options...
Madcowz Posted October 17, 2008 Share Posted October 17, 2008 You can get them on Ebay for a couple of pounds but I have never bothered as the tech archive trick works a treat. Suppose it might be an idea to buy one for the next time I have to remove the dash. Which can sometimes be a daily occurance. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted October 17, 2008 Share Posted October 17, 2008 Now I just need to repaint the elements on the window as I only have 3 working. And what with the high back seats and tyre on the door, I can't see anything behind me. What do you re-paint it with? I've a few that could do with fixing. I remember doing this way back when on an old Mk3 cortina - but since then I'd imagine there is less call for this kind of repair? and I certainly can't remember what it was called! Quote Link to comment Share on other sites More sharing options...
Cat_J Posted October 17, 2008 Author Share Posted October 17, 2008 You can get copper pens for these sorts of things. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted October 17, 2008 Share Posted October 17, 2008 Only thing I can find like that now is this from Maplins..... at £26 Quote Link to comment Share on other sites More sharing options...
western Posted October 17, 2008 Share Posted October 17, 2008 Only thing I can find like that now is this from Maplins.....at £26 Maplins do this electric conductive paint too. & repair kit scroll down to the 12th item from end of page Quote Link to comment Share on other sites More sharing options...
Madcowz Posted October 17, 2008 Share Posted October 17, 2008 Halfrauds do window electrical paint for not too much... and this was bought recently depsite the 'vintage' packaging. [Edit: same as the one Western linked to] And this is what the VSS looks like: Voltage Sensitive Switch: Part PRC4427 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 17, 2008 Share Posted October 17, 2008 Hey it's so easy and effective even a lady can do it ! Remarkable subliminal messaging Mo Quote Link to comment Share on other sites More sharing options...
Madcowz Posted October 20, 2008 Share Posted October 20, 2008 Hey it's so easy and effective even a lady can do it ! Remarkable subliminal messaging Mo Yes but only with a very steady hand. I would highly recommend buying a 0 or 00 brush and forgetting the one that comes with the kit as it is wide enough to paint the lines on the road and no use for the window. To be honest, the cardboard template that comes with the kit is useless as well. I did mine at the w/end after having the kit sat on the bench for months and it was all going well until the dog came round to see me and bumped into my legs. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 20, 2008 Share Posted October 20, 2008 That's what dogs are for Mo Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 22, 2008 Share Posted November 22, 2008 My HRW does not work. I have swapped the VSR for another one and no joy. It could be that both are duff but..... Fuse OK, but no power to the fuse. Switch works as the light on the dash comes on. Could it be the relay itself (rather than the VSR)? Would the dash light work regardless of the condition of the relay? I don't have a wiring diagram that shows the HRW circuit and even if I did I doubt I'd understand it!! All help appreciated! Quote Link to comment Share on other sites More sharing options...
western Posted November 22, 2008 Share Posted November 22, 2008 swap the relay it sits next to the yellow VSR unit. or check it's correctly fully fitted in it's holder/connector Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 22, 2008 Share Posted November 22, 2008 Tried swapping the relay, still no dice . Any other ideas folks? Quote Link to comment Share on other sites More sharing options...
western Posted November 22, 2008 Share Posted November 22, 2008 rear screen wiring diagram. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 22, 2008 Share Posted November 22, 2008 For what it's worth, when I switch mine on I get 12V at the start of the elements (bottom connector) on the window pane....but it still doesn't de-mist no matter how long I leave it for. I think maybe I need to get a new rear window pane with new elements on. Quote Link to comment Share on other sites More sharing options...
western Posted November 22, 2008 Share Posted November 22, 2008 if it's not demisting is the earth lead attached to a sound bit of body work & the other side of the screen heating elements. either that or all the elements have breaks in them. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 22, 2008 Share Posted November 22, 2008 Well it connects to the frame that holds the glass in. And there's good continuity between the connector and the main vehicle body. I wouldn't be suprised if all the elements are knackered to be honest. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 23, 2008 Share Posted November 23, 2008 Well, I spent literally minutes sucking my teeth and taking random measurements with a multimeter to no avail. I then decided to follow the advice in the tech archive and lo and behold - it works!! and only one dead fillament too! Thanks all Quote Link to comment Share on other sites More sharing options...
western Posted November 23, 2008 Share Posted November 23, 2008 a total suceess Well Done for a non sparky Quote Link to comment Share on other sites More sharing options...
