the_mouse_man Posted October 18, 2008 Share Posted October 18, 2008 As the title says really - How easy - sensible and practical is it to 'retro' fit a 300tdi to a newer td5 90. Surely this must be a nightmare - I guess mechanically it all mates up does it??? but the electrics must be a chore. What happens at MOT time (emissions) Work colleague has what he thinks is a cracked piston (Understood to be common) and is inclined to go for a 300tdi, rather than a straight swap - I think he has probably lost the plot especially as I am going to get roped in to labour/grease monkey on the project. Any comments help or advice appreciated. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 18, 2008 Share Posted October 18, 2008 Bear in mind that the 99> Defenders were produced as a 300Tdi in limited numbers for the export market right up to end of 06MY so you could actually do it with all original factory parts if you wanted to It would be a fair amount of work but is certainly doable. Quote Link to comment Share on other sites More sharing options...
dodgyjeep Posted October 18, 2008 Share Posted October 18, 2008 sounds like a nightmare, but go for a 2.8 brazilian if your gonna do it Quote Link to comment Share on other sites More sharing options...
stonie110 Posted October 18, 2008 Share Posted October 18, 2008 it would be alot of work the gearbox is different the axles and diffs are different propshafts are different the wiring is completely different i think it would be cheaper to get the engine rebuilt. Quote Link to comment Share on other sites More sharing options...
western Posted October 18, 2008 Share Posted October 18, 2008 Axles/diffs/gearboxes/props/ are the same all are used on the late 300Tdi [ROW 2006 vehicle] the wiring is slightly different as agian its used on the vehicle version mentioned ^^^^^ Quote Link to comment Share on other sites More sharing options...
dirtbox Posted October 18, 2008 Share Posted October 18, 2008 At last, someone as mad as me! Loads of people will say your mad doing it but if (like most landie owners), you like making hard work for yourself, then do it! I would! Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted October 19, 2008 Share Posted October 19, 2008 sounds like a nightmare, but go for a 2.8 brazilian if your gonna do it As he sead maybe worth the work come the end Quote Link to comment Share on other sites More sharing options...
smo Posted October 19, 2008 Share Posted October 19, 2008 Cracked piston....common???? I've never heard of any, or had one!! I'd never change a TD5 to go back to an "old" engine like a 300tdi. Get the TD5 repaired, its strets ahead of the old stuff. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 19, 2008 Share Posted October 19, 2008 At worst you'll need a Tdi gearbox bellhousing and input shaft. a pair of engine mounts engine/radiator/pipes etc. There are plenty of broken Tdi defenders, buy a complete bulkhead and strip off the bits you need (wiring loom/throttle pedal/heater/water header tank etc etc) As western says, axles & diffs are the same (OK, a late Td5 110 has a different rear axle, but that doesn't change anything). if you fit the Tdi bellhousing to the gearbox, you can weld the engine mounts to suit so nothing else needs changing. Or try contacting M&D engineering.... they do kits to convert Td5's into the international 2.8 (which is physically the same outer dimensions as a 300Tdi) so they may do a "conversion" wiring loom to change the bulkhead electrics. But like has been said.... Td5's don't regularly break pistons. just get a replacement piston or a short block. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted October 19, 2008 Share Posted October 19, 2008 Our 2.8TGV conversion guy here stopped doing TD5s as it was too much like hard work sourcing all the bits, partly because we have next to no scrap 300Tdis except those that have been in accidents. No rust + no MOT, you see. A conversion on a 300Tdi is a doddle. But the most impressive Disco I have ever driven was an auto 2.8. Absolutely no turbo latency, torque from idle, you move your right foot and it just goes! A Defender with that engine is crying out for the 1.2:1 Disco transfer box. On the TD5 piston front, we had one that broke a piston, well actually the small end disintegrated completely taking the rod and the piston with it. We bought a cheepo replacement piston. You could peel the graphite coating off with your fingernail! Still, in it went and the engine is still going ok AFAIK. (Britpart strikes again). Quote Link to comment Share on other sites More sharing options...
