rusty_wingnut Posted November 11, 2008 Share Posted November 11, 2008 1996 300tdi 90, my missus always complains about the cold, on our way back from Goodwood this year she complained it was too hot. Can't be bad? Only precaution when it gets really cold is to put a piece of cardboard over the front of the rad, leaving the intercooler free Quote Link to comment Share on other sites More sharing options...
madmatt Posted November 11, 2008 Share Posted November 11, 2008 . I wouldnt bother with those heated plates that go in the seat base, as they only warm up your bum and they aint cheap. The heated seat cover i got heats the base AND the back of the seat right up to shoulder height. I think you need to be more specific on brand there. I bought the waeco heated elements they were £48 with 4 elements 2 per seat 1 in base and 1 in the back complete with wiring loom an hour to fit and they get very very warm on maximum setting. yes they are more expensive but they are extremely good and have been going strong for 3 years. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 11, 2008 Share Posted November 11, 2008 How much current does a set like that pull off your battery then? Quote Link to comment Share on other sites More sharing options...
madmatt Posted November 11, 2008 Share Posted November 11, 2008 How much current does a set like that pull off your battery then? not a great deal I think the fuse is 10amp, It comes with a wiring loom inc switches and relays just connect one wire to ignition and one to battery + Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 11, 2008 Share Posted November 11, 2008 Where is the adjustment on the flaps? I see the heat adjustment on the top of the heater box - but the other cable seems to disappear behind it... Quote Link to comment Share on other sites More sharing options...
jonost24 Posted November 11, 2008 Share Posted November 11, 2008 I agree with V8freak. Fit a V8 . Very toaaastieeee!! Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2008 Share Posted November 11, 2008 Where is the adjustment on the flaps?I see the heat adjustment on the top of the heater box - but the other cable seems to disappear behind it... 2nd cable is on the side of the heater box. Quote Link to comment Share on other sites More sharing options...
ebdesignDEFENDER Posted November 11, 2008 Author Share Posted November 11, 2008 thanks,I was thinking of to buy heated seat covers,to take the heated elements from them and to put them under the original tim of the seats-It will be OK? Quote Link to comment Share on other sites More sharing options...
dantd5 Posted November 11, 2008 Share Posted November 11, 2008 I used my Webasto very often but spent a fortune buying new batteries.. A practrical thing was to get a real oven in my car. And it is remote controlled. I just plug it on current before going to bed.. Pling in the morning and the whole care get to 30 deg.. heated like an egg!! watch it.. http://i288.photobucket.com/albums/ll194/d...5/Roma002-1.jpg Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2008 Share Posted November 11, 2008 exmoor trim do a heated seat kit, so you can add the heating elements to existing seats. Quote Link to comment Share on other sites More sharing options...
ebdesignDEFENDER Posted November 11, 2008 Author Share Posted November 11, 2008 exmoor trim do a heated seat kit, so you can add the heating elements to existing seats. but an cheap heated covers (Lidl,Wolworh)set will do the job? Quote Link to comment Share on other sites More sharing options...
ebdesignDEFENDER Posted November 11, 2008 Author Share Posted November 11, 2008 also,I whant to change my switch of heater sistem because it is rusty.I whant to put something from another car.As I see the switch from Defender is something mecanical.Did someone changed the switch with something much better? Thanks Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 11, 2008 Share Posted November 11, 2008 2nd cable is on the side of the heater box. Thank you - I'll have a look. Quote Link to comment Share on other sites More sharing options...
martinspragg Posted November 12, 2008 Share Posted November 12, 2008 Heat! I am trying to work out how to make my ex MOD Defender cooler . But then again it's a very pleasant mid 70's at the moment and it may get down to the 60's on the odd day in Jan! I love all those windy gaps in the doors! Martin Quote Link to comment Share on other sites More sharing options...
stuntman Posted November 12, 2008 Share Posted November 12, 2008 I've just sorted out my heater last night, badly adjusted top cable! However, what does the side cable do? mine doesn't seem to move to much? Quote Link to comment Share on other sites More sharing options...
Lars L Posted November 12, 2008 Share Posted November 12, 2008 It's there to completely block off the air that goes into the heater. But as very common on a Land Rover, it simply does nothing in reality. I've left mine unattached, there's no air entering anyway if the blower is turned off. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 12, 2008 Share Posted November 12, 2008 I'm a bit confused Where is this the cable that operates the vents in the cab? Quote Link to comment Share on other sites More sharing options...
jacks906 Posted November 12, 2008 Share Posted November 12, 2008 does any one rate the webasto's been thinking of getting one off a sprinter and setting it up in my landy (one that heats the water up) anyone done the same or is it best just to go the full hog an buy a proper job also rad muff going on soon an best mod i did to get it warm an stay warm is converted it to a truck cab get proper toastie now dave Quote Link to comment Share on other sites More sharing options...
western Posted November 12, 2008 Share Posted November 12, 2008 my recent post about adjusting Defender heater control cables, click here tells you all you need to be toasty warm inside Quote Link to comment Share on other sites More sharing options...
