Green Bob Posted November 30, 2008 Share Posted November 30, 2008 After my front halfshaft decided to smash into the oil filter the other day, I decided that the colossal leak would be due to the dinked filter, so I changed it and refilled the oil. Started the engine and the substantial oil leak is still there. My guess is the prop hit something else as well, but without knowing what exactly it looked like before the clunk, I can't tell what, if anything, has changed. This is the area around the filter from below as it is now. The leak is definitely from that area. Engine is a 19J if that makes any difference. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted November 30, 2008 Share Posted November 30, 2008 How can a halfshaft smash into the filter - do you mean propshaft? Anyway, clean the area with a degreaser and it will be a lot easier to trace where the leak is coming from. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 30, 2008 Share Posted November 30, 2008 From that picture I can say it's definitely coming from the black bit Quote Link to comment Share on other sites More sharing options...
western Posted November 30, 2008 Share Posted November 30, 2008 examine the flange area of the oil cooler hose 'turret' casing, mine cracked off & leaked oil out, or the oil pressure switch maybe damaged & leaking. defo needs a good clean first. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 30, 2008 Share Posted November 30, 2008 The fact the terminal on the oil pressure switch is bent & the wire's not on suggests it's been hit. Cleaning the thing up is the only way to be sure though, could be anything. Quote Link to comment Share on other sites More sharing options...
santalars Posted December 1, 2008 Share Posted December 1, 2008 Agree. But how can the halfshaft or the propshaft hit the oil filter??? Quote Link to comment Share on other sites More sharing options...
Green Bob Posted December 1, 2008 Author Share Posted December 1, 2008 Cheers. Looks like it's the oil pressure switch that needs replacing. Propshaft flange sheared and sent it into the filter and the sump, got three nice gouges in my sump as well, but no penetration... Quote Link to comment Share on other sites More sharing options...
jonost24 Posted December 1, 2008 Share Posted December 1, 2008 Mmmmmm..........no penetration........ Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted December 1, 2008 Share Posted December 1, 2008 Again - clean the area and watch for leaks. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 2, 2008 Share Posted December 2, 2008 How can a halfshaft smash into the filter Bathtub driving? Quote Link to comment Share on other sites More sharing options...
