Jammy123 Posted December 18, 2008 Share Posted December 18, 2008 Just come to remove my standard bumper, but the bolts just seem to be turning? Are there meant to be captive nuts? How can i get to them as i cant see anything? Also hat bolts/nuts are they? Im after getting replacements? Cheers Quote Link to comment Share on other sites More sharing options...
MJIbex Posted December 18, 2008 Share Posted December 18, 2008 The 2 nuts are meant to be held by a metal clip that hooks onto the chassis, it invariabley rusts. From memory you should be able to get a spanner in from behind and the middle side on the a standard bumper. Mark. Quote Link to comment Share on other sites More sharing options...
western Posted December 18, 2008 Share Posted December 18, 2008 item 2 clips on to the bottom face of the front chassis legs, maybe the clip is busted or well corroded to let the blots unscrew. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted December 18, 2008 Share Posted December 18, 2008 item 2 clips on to the bottom face of the front chassis legs, maybe the clip is busted or well corroded to let the blots unscrew. I had lots of headache getting my standard bumper off to replace it with winch bumpers. You need to insert a screw or a chisel to lock it from rotating! Need loads of patience too!! . The nr 2 Ralph is talking about is the culprit for sure!! Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted December 18, 2008 Share Posted December 18, 2008 Clip nuts are always a pain in the arse. My preferred means of removal is by drilling the bolt heads out. Centre pop the bolt head and start with 3mm drill then work up until the head comes away, can always persuade them with a cold chisel when you get up to thread core diameter. Have fun Rob Quote Link to comment Share on other sites More sharing options...
landydave Posted December 19, 2008 Share Posted December 19, 2008 Sorry to hijack the thread, but i'm trying to get my bumper bolts out to get an A-Bar on. The bolts come out OK but i'm afraid that the small plate they screw into will fall into the chassis and i'll never get it back. How do i keep the plate ready to take the bolts again when there's only the tiny hole in the side of the chassis to get a finger in? Ta DAVE Quote Link to comment Share on other sites More sharing options...
Alan Broadbent Posted December 19, 2008 Share Posted December 19, 2008 Suprised that the whole threaded block held in place is turning - I thought that it was prevented from doing so by the chassis member. Suggest that you try chocking it somehow. Replacement clips and threaded block from LR dealers are not too pricey. Alan Quote Link to comment Share on other sites More sharing options...
yellow Posted December 19, 2008 Share Posted December 19, 2008 Sorry to hijack the thread, but i'm trying to get my bumper bolts out to get an A-Bar on. The bolts come out OK but i'm afraid that the small plate they screw into will fall into the chassis and i'll never get it back. How do i keep the plate ready to take the bolts again when there's only the tiny hole in the side of the chassis to get a finger in?Ta DAVE They will inevitably fall in, but are quite easy to fish out immediately. It helps if you have washed out the area first washing away the mud with plenty of water, and have a set of fingers available for dropping the long bolt through the hole once you've lined up everything... Practice makes perfect... Quote Link to comment Share on other sites More sharing options...
dantd5 Posted December 19, 2008 Share Posted December 19, 2008 In my early days, I designed a metal hook and when I lost it, fished it up. It is some of these petty petty tasks that takes so much time you regret even attempting to remove the bumper. Use a hook (not fish hook mate) Be patient and it will evitably come up! Quote Link to comment Share on other sites More sharing options...
JST Posted December 20, 2008 Share Posted December 20, 2008 take the rubber bung out the end of the chassis rail and use two screwdrivers to manipulate the part up, then use the lower screwdriver through the bung hole as a pivot to locate it onto the end of the bolt, then turn the bolt 1/2 drive and long extensions help after removing the plastic grill Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted December 20, 2008 Share Posted December 20, 2008 Hi On mine I trimmed the "chin" bit off the chassis enabling me to stick bolts through and get nuts on the other side, MUCH less hassle than hours fiddling with that effing plate thing, my bumper has the jack holes in so no loss... Mike Quote Link to comment Share on other sites More sharing options...
landydave Posted December 20, 2008 Share Posted December 20, 2008 They will inevitably fall in, but are quite easy to fish out immediately. It helps if you have washed out the area first washing away the mud with plenty of water, and have a set of fingers available for dropping the long bolt through the hole once you've lined up everything... Practice makes perfect... Thanks All sorted now although it helps not to have sausage fingers! It turns out the A-bar i bought has unusual spotlight clamp locations and so i'm having to send my spots back to Simmonites for smaller one's (and i had to butcher the rad grill to get it back on. Grrrrr Here's hoping smaller lamps fit! Dave Quote Link to comment Share on other sites More sharing options...
Jammy123 Posted December 24, 2008 Author Share Posted December 24, 2008 I fitted the new bumper yesterday but what an arse of a job...the bumper bolts were all seized, although removing the old threaded block was dead easy with a screwdriver stuck in to stop it turning. The clips were totally fooked! LR wanted £16 per clip!, and did not even stock them but a local parts supplier sold the clip and block as a set which only cost £16 for two. Getting the blocks into position was my biggest problem as i could not get the bolt thread started. After what felt like an eternity I got one started and then the other side went in nearly straight away!! The HD FirstFour bumper looks spot on thouugh!! Now just need to grind the steering guard so it fits between the 2 recovery points on the bottom of the bumper. Quote Link to comment Share on other sites More sharing options...
Briarston Posted December 24, 2008 Share Posted December 24, 2008 Just come to remove my standard bumper, but the bolts just seem to be turning? Are there meant to be captive nuts? How can i get to them as i cant see anything?Also hat bolts/nuts are they? Im after getting replacements? Cheers When I tried to remove mine, 2 sheared off, one was already sheared and the 4th. unscrewed. There were no clips holding the "captives" in place. One bolt broke about an inch above the plate stopping me wangling it out. A real pain cutting it off with a bare hacksaw blade. I bought(!) four new bolts and nuts, drilled out what used to be tapped holes in the plates, and welded the nuts on. Refitted with plenty of copperslip, but a bit of a fiddle to get them lined up with the bolt holes. Quote Link to comment Share on other sites More sharing options...
western Posted December 24, 2008 Share Posted December 24, 2008 These are the standard bumper bolts & nut plates. found these on ebay here Quote Link to comment Share on other sites More sharing options...
Jammy123 Posted December 25, 2008 Author Share Posted December 25, 2008 Oh I just spent £16 on the threaded block and clips alone!!! Quote Link to comment Share on other sites More sharing options...
