Hose thing
Dazza
Hi All
Got a bit of a weird question
I need to find the hose that goes between the airfilter housing and the engine (the 3 inch diamater piece) as mine has broken, the problem i have got is i dont know what it is called and i cannot find it on the web.
Please HELP :unsure:
I'd call it air intake ducting but I don't know what the Land Rover part name is, probably something stupid that you would never think of typing into Google as that is what they normally do. Somebody with a copy of Microcat will no doubt be along with a part number for you in due course.
Dazza, I suggest you change your sig to show what LR you own, then you don't have to tell us. And some indication of where you are in the world makes a big difference to the answers you will get. Cheers, Jim
Thanks for the pointer :lol:
I am in Hampshire
You can buy it by the metre from Hyphose. It's Wyrem flexible ducting you want and costs about £20 per metre last time I bought any. You may need a "top hat" adapter piece if the diameters are different (from memory they are), but worth a look before splashing out £40+ to Rimmers. Failing that, Martin Toole at Nursling Southampton will have one, 07885 399785.
I got ESR1807 from Ripon Land Rover on181208 for £13-81 inc VAT. They had to get it in overnight because they don't carry them.
I expect your local dealership can do the same........... :rolleyes:
Hope that helps...........
Rimmer's price is £13.05inc VAT so ESR1807 it's the cheapest of the two hoses, strange that <_<
