ibexman Posted June 19, 2009 Share Posted June 19, 2009 Wheres your anderson plug outlet mounted post up pics please Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted June 19, 2009 Share Posted June 19, 2009 No pictures... but mine is mounted horizontally across the face of the seat box on the passenger side. Nice and easy to access and muck is not an issue as they are happy being jet washed! (caps are available if you really want to keep the carp out) Quote Link to comment Share on other sites More sharing options...
landrover598 Posted June 19, 2009 Share Posted June 19, 2009 By the rear door on the inside. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted June 19, 2009 Share Posted June 19, 2009 one on the front bumper next to the winch and the other just inside the back door kind of like above ^^ Quote Link to comment Share on other sites More sharing options...
reads90 Posted June 19, 2009 Share Posted June 19, 2009 Mine is fitted on the rear under the cross member . It is in the same place on my 90 and 110. It is mounted here to power and recharge the battery in the camper trailer You can see it on the 90 here . It is just to the left of the tow hitch . The oposite side to the trailer electircs plug Quote Link to comment Share on other sites More sharing options...
errol209 Posted June 20, 2009 Share Posted June 20, 2009 Under the bonnet, where the f****n battery aught to be . Allows you to drive up to standed fellow motorists rather than having park accross them. Plus, I park against NS to hedge, and my jump leads aren't long enough when I've overdone using the insp. light and listening to the cricket! Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 20, 2009 Share Posted June 20, 2009 I have the female Anderson socket under my cross member but no plug with jump leads yet - any suggestions on where to get some? Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted June 20, 2009 Share Posted June 20, 2009 the anderson plugs are opposites of each other ie theres no male or female, 'getconnectedplugs' on ebay is by far the cheapest place to get them, just buy a set of jump leads and cut one end off... Mike Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted June 20, 2009 Share Posted June 20, 2009 here you go http://stores.shop.ebay.co.uk/GET-CONNECTED-PLUGS Mike Quote Link to comment Share on other sites More sharing options...
smo Posted June 20, 2009 Share Posted June 20, 2009 I had one mounted on the front bumper next to the winch on my 90, the d-lander doesnt and wont have one at all. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 20, 2009 Share Posted June 20, 2009 Excellent! - thanks Guys! Quote Link to comment Share on other sites More sharing options...
zim Posted June 20, 2009 Share Posted June 20, 2009 what size does everyone use ? Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted June 20, 2009 Share Posted June 20, 2009 mine are for jump starting, the 175A ones are fine for this as its only a short term use, If its for long term ie winching then maybe the 350A one would be better... Mike Quote Link to comment Share on other sites More sharing options...
mattltm Posted June 21, 2009 Share Posted June 21, 2009 I have mine mounted on the front of the passenger seat box... And some nice 6M long jump leads.. Quote Link to comment Share on other sites More sharing options...
leeds Posted June 21, 2009 Share Posted June 21, 2009 I have mine mounted at the top of the battery box. Does not get kicked by passenger and is relatively high so out of the way of any mud/water which gets into cab Front view Top/side view Hope that is of some use Regards Brendan Quote Link to comment Share on other sites More sharing options...
