bishbosh Posted September 24, 2009 Share Posted September 24, 2009 Is a split TRE gaiter an MOT fail? There is no play in the TRE, but the gaiter has been pinched and has split. It is on the hub end of the drag ink if that makes any difference. Thanks, Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 24, 2009 Share Posted September 24, 2009 I think so, similar to a split CV boot ....which I had.... as an MOT Fail. Not 100% .....but pretty sure (if he notices it ) Nige Quote Link to comment Share on other sites More sharing options...
white90 Posted September 24, 2009 Share Posted September 24, 2009 yes if they see it, it is Bit of Silicon/RTV? I have spares here if you want me to post you one? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted September 24, 2009 Share Posted September 24, 2009 I think a split CV gaiter is a fail under section E1a, see http://www.motuk.co.uk/manual_250.htm Whereas a TRE gaiter (dust cover) is only an advisory (or whatever it's called), according to http://www.motuk.co.uk/manual_220.htm (see Steering Joint dust cover). Don't shoot the messenger as he's not that familiar with the UK MOT system (but it's pretty much the same in EU). Quote Link to comment Share on other sites More sharing options...
steve_d Posted September 24, 2009 Share Posted September 24, 2009 You won't get away with this on a CV because of all the movement but you can fix a split TRE gaiter with superglue as it loves rubber. Have to get it very clean and degreased but it works well. Steve Quote Link to comment Share on other sites More sharing options...
ciderman Posted September 24, 2009 Share Posted September 24, 2009 CV and steering rack gaiters split are a reason for failure , Split TRE boot is not a reason for failure , Its an advisory , Have you submitted it for test yet Bish , Just for piece of mind stick a new joint on ,for less than 25 quid do the lot . A split boot aint going to get better and repairing them is more hassle than its worth . Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted September 24, 2009 Share Posted September 24, 2009 Is a split TRE gaiter an MOT fail? There is no play in the TRE, but the gaiter has been pinched and has split. It is on the hub end of the drag ink if that makes any difference. Thanks, Pass and advise, it doesn't even come under the steering section, it a non-component related advisery Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 25, 2009 Author Share Posted September 25, 2009 Thanks folks. I do have spares so will change it soon, but I am not going to have a chance to between now and the test. Tony, thanks for the offer of spares. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 2, 2009 Author Share Posted October 2, 2009 Well it was MOT'd today. TRE gaiter not a problem, but the absence of one of the two poxy little bolts used to locate the A frame ball joint was! The annoying thing is that it has been like that for 3 years and MOT'd at the same place each time. The ball joint went in slightly crooked so I could only get one of the bolts in. Ho hum. New ball joint tomorrow then. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted October 2, 2009 Share Posted October 2, 2009 Bolt head and araldite Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted October 3, 2009 Share Posted October 3, 2009 Well it was MOT'd today. TRE gaiter not a problem, but the absence of one of the two poxy little bolts used to locate the A frame ball joint was! The annoying thing is that it has been like that for 3 years and MOT'd at the same place each time. The ball joint went in slightly crooked so I could only get one of the bolts in. Ho hum. New ball joint tomorrow then. my mot tester on Thursday failed on a brake pipe not being secure he past it last year but to be fair he did let me fix it so it passed in the end Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 3, 2009 Author Share Posted October 3, 2009 Bolt head and araldite Did contemplate that one, but don't really want to risk it being found out on (free) retest ans then having to buy a new ball joint and pay for another MOT. Quote Link to comment Share on other sites More sharing options...
pat_pending Posted October 3, 2009 Share Posted October 3, 2009 If there's nothing wrong with the joint, it's just a misaligned hole, then run a drill down from the top to clear the overlap then follow it through with a tap. Should be able to fit the bolt then. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 3, 2009 Author Share Posted October 3, 2009 I just removed the joint from the a frame and axle and enlarged the hole in the joint flange plate. Two bolts in now so free retest next week.... Quote Link to comment Share on other sites More sharing options...
JST Posted October 7, 2009 Share Posted October 7, 2009 i see it wasnt an issue but to add to it i have only had advisorys for split rubbers.... on TRE Quote Link to comment Share on other sites More sharing options...
