No DOE
My 90 has failed the DOE (MOT equivalent in Ireland) yesterday.
13 complaints in total, 10 of these are like "worn out door hinge", "loose wires in engine bay"
Will get them easily sorted over the weekend.
However one of the serious ones was "poor brakes".
They miracusly found differential braking on application of the parking brake.
Could anyone tell me how this is possible when the brake on the propshaft?
I would have thought that both wheel will be absolutely the same than.
I have new cylinders in the calipers and new braided hoses. New pad as well. The bias valve looks optically a bit poor (corrosion).
As I need to improve the brake performance, would you think it's rather the bias valve or the master cylinder which needs replacement.
I would have thought that bad brake performance comes as a standard with a Defender. Although I personally think that my brakes are really good.
"...They miracusly found differential braking on application of the parking brake....
I would have thought that both wheel will be absolutely the same..."
Could that be because the braking force is applied via a differential?
If you apply the handbrake where there is less grip on one side then one wheel will carry on rolling and the one with least grip will slip, maybe even turn backwards.
Sounds to me like your tester has no experience of transmission brakes, or Land Rovers in general. :rolleyes:
If you need to improve brake balance, then first I'd recommend a good clean and service of the the brake components. Have you a drum-brake rear axle? It seems as though you have disk all round but Im not sure...a hugh number of people never adjust the drum brakes and wonder why they dont work properly..
When you say the pads are new..are they brand spanking new, or have they done a few miles and bedded in?
I take it they tested the brakes on the road...and the handbrake on a hill.....
I think I'd be seeking a second opinion myself...but I'm not familiar with the differences between MOT and DOE
  • 2 weeks later...
Ok, I have sorted everything, but I have again failed the DOE.
All ok, except from the rear brake effectiveness.
There are 3% missing (and this is afer some slight manipulation of a computerised testing rig).
Master Cylinder: New
Bias Valve: New
Rear caliper pistons and seals: New
Rear break hose: 2 year old goodrich braided hose
Rear pads: new
Rear disks: good
System bleeded excessively
We have closely checked the brakes and there appears to be nothing wrong.
All copper pipes and they are fine.
I will now replace the rear calipers with new ones (yes, I'm that desperate) and will put in a new hose.
Any ideas what else could be worng????
Go to J L Bradshaws in Portlaoise.
You have to book etc.
Jimmy tests my 109 every year - does some other LRs. Honest and by the book.
Isn't after a bribe like most of them, nor does he give a stuff about making work for the garage, as there isn't a garage.
If it isn't right it fails, and vice versa.
g.
