disco 1 headlight upgrade to td5
200 inside
Early Td5 headlights onto a 300 are easy (just swap them), late Td5 four-eyed headlights are much harder and anything onto a 200 Disco is likely to be really hard but will need to know exactly what you are putting onto what, to give exact instructions
I have a 300 conversion on my 200, not a lot of work, but a good cutting pattern is needed, (I used the panels off a 300)
the early disco 2 headlighs are a straight swap for 300 headlights, but the facelift ones need a LOT of cutting, and chopping the wings, I have seen it done, anything is possible on a landrover.
The early 99-02 headlights are the same fitting as a 300Tdi but have the "slightly smoked around the edges" look so purely cosmetic improvement.
Later ones have the four-eyed headlights which means more light but are a PITA to fit and I would guess the wiring needs to be revised as well as you get dip and main on at the same time in those rather than one or the other.
  • 1 year later...
Hi all. I've just had one of my headlights destroyed *grumble* and can get a pair of early D2 (pre facelift) ones for a reasonable price. The LR specialist dismantler reckons they won't fit my D1 update ('94-on), whereas my understand was they would, and that's the general consensus above. Can someone who has actually done this swap confirm it is do-able and whether it's plug&play or there are any tweaks required before I put down my hard-earned? Much appreciated. Cheers.
switching to the 99-02 disco 2 lights on a series 1 disco is a straight swap, unclip the 3 adjusters from the front panel (pull the pin and twist 1/3rd of a turn, unplug the wiring, swap the new lamp over (you may have to swap the adjusters if they are new lights) clip in job done - simples.
Good suggestion. We can't easily get them in Aus (unless bought from LR for mental $$$$s). So I have just ordered a vehicle set... but got stung for VAT, and the seller wasn't willing to remove it. Bugger. :angry:
Oh, well. New lights to be picked up on Thursday, and clips now on their way :D
My brother picked up my new D2 headlights for me today. I'll get them on the weekend :D They look like they're the Magnetti-Marelli aftermarket ones off the OE tool (logo still there, but ground off). AU$210 for the pair, which I thought was quite reasonable. That'd be about £130 at current exchange rates, for those of you in the old country.
Will post pics once fitted of before & after. Only two more sleeps.... :P
Thanks for the advice.
