SiWhite Posted April 27, 2006 Share Posted April 27, 2006 I'm looking for a 52mm tacho for the Landy, to fit a diesel. I know Low Tension.com used to sell them, but I can't find thier t'internet site anywhere. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted April 27, 2006 Share Posted April 27, 2006 Something like this ? Quote Link to comment Share on other sites More sharing options...
Porny Posted April 27, 2006 Share Posted April 27, 2006 Low tension aren't around anymore AFAIK.... the unit they used to work from is now a football kit printers/sport kit outlet. But the above link isn't badly priced though.... The other place that sells the VDO stuff is Croytec - http://www.croytec.co.uk - not cheap though. Ian Quote Link to comment Share on other sites More sharing options...
headhunter Posted April 27, 2006 Share Posted April 27, 2006 The one I bought from low tension is made by VDO and fits in well with the fuel and temp gauges. So I suggest finding a VDO retailer who should be able to help. John Quote Link to comment Share on other sites More sharing options...
02GF74 Posted April 27, 2006 Share Posted April 27, 2006 just curious, what triggers them since there is no igntion coil. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 27, 2006 Share Posted April 27, 2006 The W terminal on the alternator. it's taken off a winding, before its rectified, i.e the tacho sees a sine wave, rather than a pulse. I've got a VDO one, VDO are OEM manufacturers for a lot of makes, including LR. Luke Quote Link to comment Share on other sites More sharing options...
02GF74 Posted April 27, 2006 Share Posted April 27, 2006 The W terminal on the alternator.it's taken off a winding, before its rectified, i.e the tacho sees a sine wave, rather than a pulse. I've got a VDO one, VDO are OEM manufacturers for a lot of makes, including LR. Luke yeqah, I knew that - ofcourse it goes to pot if the pulleys are not the original size. but if it didn't have this terminal, guess you can't? (well not easily ) Quote Link to comment Share on other sites More sharing options...
MarkieB Posted April 27, 2006 Share Posted April 27, 2006 yeqah, I knew that - ofcourse it goes to pot if the pulleys are not the original size. but if it didn't have this terminal, guess you can't? (well not easily ) The tachos are adjustable, you set them up with a strobe connected to a petrol engine at a known speed Quote Link to comment Share on other sites More sharing options...
MogLite Posted April 27, 2006 Share Posted April 27, 2006 The tachos are adjustable, you set them up with a strobe connected to a petrol engine at a known speed Or just set it to factory idle speed when the diesel is idling. Try Merlin Motorsports for VDO stuff or egauges.com to mail order from the US Quote Link to comment Share on other sites More sharing options...
will_warne Posted April 27, 2006 Share Posted April 27, 2006 Or just set it to factory idle speed when the diesel is idling. That's what I did and i fing it plenty accurate enough. Si, I assume you've got a Disco Alternator? IIRC the Defender one's don't have a W terminal. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 27, 2006 Share Posted April 27, 2006 Mine does, though it is a 65A alternator, originally fitted to air con models Quote Link to comment Share on other sites More sharing options...
simonb Posted April 27, 2006 Share Posted April 27, 2006 200 and 300Tdi alternators usually have a w terminal as standard but it is hidden under a plastic cover. Its a bolt style terminal on the opposite side to the output terminal. Quote Link to comment Share on other sites More sharing options...
western Posted April 27, 2006 Share Posted April 27, 2006 Rev counter/Tacho on Tdi engines for 90/110/Defenders Quote Link to comment Share on other sites More sharing options...
