kingrat Posted April 22, 2010 Share Posted April 22, 2010 Fancy using this to get rid of the gunk underneath the 110. I'm a bit concerned by the fact it states do not use on aluminium. Any one used it with success? Or do you think it relates to the fact it would dull kitchen aluminium? Cheers Paul Quote Link to comment Share on other sites More sharing options...
rtbarton Posted April 22, 2010 Share Posted April 22, 2010 It's basically caustic soda which will dissolve ally, let alone dull it. Quote Link to comment Share on other sites More sharing options...
kingrat Posted April 22, 2010 Author Share Posted April 22, 2010 ta for that. I think I'll not use it in that case. Trust a Yorkshireman to go for the cheap option. Suppose I'll donate it to SWMBO and see if she gets off her a**e and cleans the oven then Quote Link to comment Share on other sites More sharing options...
TSD Posted April 22, 2010 Share Posted April 22, 2010 Worked fine for me, just made sure it was well rinsed off and wiped over with an oly rag afterwards. Quote Link to comment Share on other sites More sharing options...
Mark Posted April 22, 2010 Share Posted April 22, 2010 What's wrong with using a proper water miscible degreaser? a 5l tin isn't that dear, and will give you loads more use than just your gearbox? just curious.... Mark Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 22, 2010 Share Posted April 22, 2010 Where can I get some Mark? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 22, 2010 Share Posted April 22, 2010 Jizer is good stuff, but then so is paraffin. Les. Quote Link to comment Share on other sites More sharing options...
PeterW Posted April 22, 2010 Share Posted April 22, 2010 Jizer is good stuff, but then so is paraffin. Les. Autoglym Engine & Machine Cleaner is on 3 for 2 at Halfrauds here Its very good, and is supposedly environmentally friendly ! Cheers Peter Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 22, 2010 Share Posted April 22, 2010 Jizer is good stuff, but then so is paraffin. Les. What he said .. I think Gunk isn't as strong but does leave a bit of a film for temporary corrosion protection. Jizer seems to get it squeaky clean. Quote Link to comment Share on other sites More sharing options...
Mark Posted April 22, 2010 Share Posted April 22, 2010 Any decent motor factors should carry some form of degreaser - I have used jizer to good effect as well as miller's or similar water miscible degreaser. Halfords stock it as has been said, but probably isn't the cheapest. Quote Link to comment Share on other sites More sharing options...
fozsug Posted April 22, 2010 Share Posted April 22, 2010 I use tetroseal deagreaser brush or spray on wash off 25 liters 25 quid, as good as jizer half the price Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 23, 2010 Share Posted April 23, 2010 I just got some white spirit. At the moment this is £1.05 per litre (Wickes). If whatever you get is meant for the job and its less than that, i'd go for it. Quote Link to comment Share on other sites More sharing options...
ajh Posted April 27, 2010 Share Posted April 27, 2010 Foaming engine cleaner and a pressure washer seems to do the best job. Quote Link to comment Share on other sites More sharing options...
Pinn76 Posted April 27, 2010 Share Posted April 27, 2010 I usd a cheap kitchen degreaser from Lidl's, G4 or G5 in an orange bottle. worked a treat when the oil cooler pipes split and emptied the contents on the road. Also cleaned that aswel!! HTH Bri Quote Link to comment Share on other sites More sharing options...
