tweetyduck Posted September 27, 2010 Share Posted September 27, 2010 If i wanted to swap my boost alloys for Wolf / Steel wheels which size do i get. I obviously want new tyres also but is there a standard size for Wolf / Steel wheels for my 110 defender ? The ones i can see on Ebay have 205/80r16xpc tyres. Is this the right size. I know nothing about offsets etc,,, so your help is appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 27, 2010 Share Posted September 27, 2010 110's with boost alloys were fitted with 235/85 R16 tyres, so you're probably after a similar sized set? The 205's will look tiddly Wolf rims are all the same as far as I know. 16", but I dont know how wide. Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted September 27, 2010 Share Posted September 27, 2010 6.5" wide Dave. Quote Link to comment Share on other sites More sharing options...
DaveSIIA Posted September 27, 2010 Share Posted September 27, 2010 There are two types - tubed (ANR5593) or tubeless (ANR4583). I would go for the tubeless version and (obviously) tubeless tyres. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 27, 2010 Author Share Posted September 27, 2010 So as the rims are 16 can you fit the same tyres i.e 235/85 ? Not wanting to start an argument...... Will the hubs i have with the Boosts work. I think i saw something about longer bolts? (obviously the nuts need changing for the not capped type) Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 27, 2010 Share Posted September 27, 2010 I'd go for either some 7.50R16 tyres, or the metric equivalent which these days is 235/85/R16. Goodrich recommend a rim width of 6" - 7" for 235/85/R16 All Terrains, so that would be about right. You'll need steel wheel nuts yes. As for the studs, technically they 'should' be longer for Wolf HD wheels, but in practice it matters little and plenty of people use them without any issues at all. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 27, 2010 Author Share Posted September 27, 2010 Thanks. Without sounding thick. Those wheels i;ve seen should be OK for me fitted with a larger tyre and mean i can ditch (sell) my Boost Alloys. Thanks all for the help. This is really quite confusing. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 27, 2010 Share Posted September 27, 2010 I have wolf wheels on my 90. Studs are about a thread and a bit short on the front. The back ones are perfect (old RR axle). Supposed to have longer studs, I think I would if my truck was more heavily loaded. Quote Link to comment Share on other sites More sharing options...
western Posted September 27, 2010 Share Posted September 27, 2010 Wolf/XD wheel studs are the same length as the civvy 90/110 studs regardless of rear drum or disc brakes, I've been through this comparison myself & there's a thread about these studs in here, just search for it. Quote Link to comment Share on other sites More sharing options...
headhunter Posted September 28, 2010 Share Posted September 28, 2010 My wolf wheels have 255/85/16 BFG MT's. This set-up gives extra ground clearance, wheel diameter is c33" I believe this is as wide a tyre safely recommended for wolf rims. However you take the risk of not while on expedition in remote locations being able to find a 255/85/16 tyre should you shred one or two. On my recent Morocco trip I took a second spare. Next time I will not as the tyres held up brilliantly despite some very hard rocky tracks near the Algerian border. South beyond Morocco I would travel as light as possible using standard items that can easily be sourced locally. Wolf Rims allowed of course. John Quote Link to comment Share on other sites More sharing options...
Marco Posted September 28, 2010 Share Posted September 28, 2010 Running General Grabber AT2 235/85x16 on Tubeless Wolf rims, standard wheel studs (bit short), now at 80.000km, no problems with studs or wheels. Cheers Marco Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 28, 2010 Author Share Posted September 28, 2010 Thanks again all. This raises another question but has nicely answered the first one. I think i'm goign to bite the bullet and order 6 new wheels from Craddocks. Will i be able to get 235/85 all over the place when on my trip ? I'm not sure i want to go bigger and i can swap over my current tyres to save a bit of money. I already have 6 tyres all GG AT 235/85. Quote Link to comment Share on other sites More sharing options...
