Torque wrench settings - lower pin bolts
Ok. Thanks a lot for your help. I'm rebuilding my front axle and now I've found that the new swivel pin won't fit into the new swivel bearings. The old swivel pin will fit into new bearing. Should I just use the old one?
I baught timken bearings and britpart pins when i did my front axle, and the pins wouldnt fit.
Sent them back and got bearmach pins instead, which worked perfectly.
Using the old pins will be fine so long as they're a snug fit with no play etc.
Hmm, I need to recheck tomorrow. But is it ok to reuse the old upper pin?
if the pin is corrosion free and shows no signs of wear then yes... i learnt the harder way and re-used the lower pin as it looked "ok" with only a slight polished area on them... i was wrong had play in the swivel i couldn't pre load out, so ended up getting some oem lower pins, bearmarch i think, solved the problem straight off.
