Gromit Posted June 16, 2006 Share Posted June 16, 2006 As I'm getting through all the mechanical stuff, thoughts turn to waxoiling the 110. I looked about Hanfords at their presurisable drum and spraying kit. Is one drum enough for a 110? How's the spraying kit? any tips? I know it's wise to heat it before use and lock the cat up. Cheers, Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 16, 2006 Share Posted June 16, 2006 I think Mr Parkinson once stated that it takes some huge amount like 20 litres I would buy 5-litres and go from there. Les. Quote Link to comment Share on other sites More sharing options...
freeagent Posted June 17, 2006 Share Posted June 17, 2006 i agree with 'im, and in fact had this very conversation with 'im today... buy 5 litres and see how it goes, you'll probably need to thin it down a little with white spirit anyway.... 5 litres did my 110 ok.... ....wait for the inevitable reply from a certain individual though...... who i'm sure insists he uses 30 litres on a 110.... Quote Link to comment Share on other sites More sharing options...
Fatboy Posted June 18, 2006 Share Posted June 18, 2006 G, As above, start with 5 litres. I ended up with about 10 litres on the Disco. Be prepared to get minging with the stuff... Don't do it over a prized driveway without a tarpaulin or something like that to catch drips because they soak into lockblok and are impossible to remove. Do not heat with a flame or gas hob. Safest to soak in a bucket of boiling water and shake it about a bit / change the water until it is runny. I wear disposable overalls and latex gloves. Don't spray waxoyl anywhere that your missus might rub against, use the stonechip for that (it goes hard). Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 18, 2006 Share Posted June 18, 2006 shake it about a bit I don't think it's wise to Disco dance while doing this job. change the water until it is runny I thought water was quite runny anyway? Got a coat I can borrow? Les. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted June 18, 2006 Share Posted June 18, 2006 I'll hold the door.... Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted June 18, 2006 Share Posted June 18, 2006 Is one drum enough for a 110? Depends how many cats you want to do. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted June 18, 2006 Share Posted June 18, 2006 I once did a lengthy post on a now defunct forum on how I go about Waxoyling. I think I kept a copy on disc so should be able to dig it out and post it if anyone is interested. Quote Link to comment Share on other sites More sharing options...
SteveG Posted June 18, 2006 Share Posted June 18, 2006 Don't spray waxoyl anywhere that your missus might rub against, use the stonechip for that (it goes hard). Are we still talking about the 110, or is stonechip the new Viagra?? Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted June 18, 2006 Share Posted June 18, 2006 How's the spraying kit? any tips? I know it's wise to heat it before use and lock the cat up. Don't use a naked flame, like wot I did or you'll end up with no eyebrows, a spectacular rocket and a black oily garage ceiling! Oh yes, I got through about 8 or so litres on the 90. Still cleaning up the mess 6 months down the line. My tip - do it some where other than your property. Quote Link to comment Share on other sites More sharing options...
Julian Posted June 19, 2006 Share Posted June 19, 2006 Just a thought. Check out Morris Lubricants 'Ankor Wax.' In my opinion it's a far better product than Waxoyl, you seem to get a thicker more resilient coating that dries quickly. I've been using it for a while now and am very pleased. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 19, 2006 Share Posted June 19, 2006 Blimey, you'd have to be careful how you pronounce that! MOG - I remember the pics you posted after waxoyling the underside of your 127(?) perfect job if I remember correctly. Les. Quote Link to comment Share on other sites More sharing options...
