davyd8899 Posted March 18, 2012 Share Posted March 18, 2012 I come again looking for guidance i have been offered a TD5 engine out of a disco for next to no money as the car was rear ended and the owner decided to break it rather than scrap/repair it. so what do i need to look out for if and when i do the transplant? or is it not possible?? Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted March 18, 2012 Share Posted March 18, 2012 It is easy to convert but can be costly. You will need to get complete wiring looms (eBay) a throttle assembly and ecu from a DEFENDER. Get as much pipe work etc as you can with the engine. You'll need a defender td5 gearbox too. The gearbox is a straight swap and will give you the mounting position for the engine mounts. I've done this exact conversion and it's not too taxing . The wiring is the easy bit if you buy complete looms as they all just plug and play. I have loads of info and tips if you get stuck along the way. Steve Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted March 18, 2012 Share Posted March 18, 2012 Just interested, surely the gear levers on a defender gearbox would end up under a Disco's dash? Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted March 18, 2012 Share Posted March 18, 2012 Sorry I just assumed it was going in a defender, my bad. Just seen its in discovery forum. Apart from gearbox and throttle pedal, if fitting to a D1 you still will need defender wiring harness and ecu as these are stand alone and not connected to becm etc. Steve Quote Link to comment Share on other sites More sharing options...
davyd8899 Posted March 18, 2012 Author Share Posted March 18, 2012 just to reiterate the TD5 engine is out of a disco NOT a defender so does this mean i still need a defender looms or do i need disco looms? and are these still plug and play so to speak ok so i need a gearbox out of a TD5 disco?? will this will bolt straight onto the 300 transfer box? and bolt straight onto the gearbox mounts to give me the location of the engine mounts am sure the props are different on the 300tdi to a TD5 thats why i ask also can the 300 running gear cope with the (modest) uprate in power the TD5 engine will give? can i plumb into the existing fuel system or will that need any modifications? finally, can i use the 300 instrument binnicle? i can get the binnicle out of the TD5 if needs must these are my main concerns and if i get the green light on these without too much aggro then i will go for it Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted March 18, 2012 Share Posted March 18, 2012 I thought they all used the R380 gearbox, if so I can't see why you would need to change the 'box. Either way the transfer box is the same so won't need changing, thus you shouldn't need to change the props. I should point out that this is only hypothesis on my part as I've never done it. Good luck though, sounds like an ideal mix to me so I shall watch with interest. Quote Link to comment Share on other sites More sharing options...
davyd8899 Posted March 18, 2012 Author Share Posted March 18, 2012 i was also under the impression they all used R380 boxes though wasnt sure if the splines were the same on the input shaft, am guessing thats why,if it is necessery, to swap the boxes over. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted March 19, 2012 Share Posted March 19, 2012 The td5 r380 is different to the 300 r380 and not interchangeable with their respective engines. Regardless of whether your engine is coming from disco or defender you will still need defender looms and ecu to make it work out of the D2. As explained earlier defender ecu's are stand alone whereas the D2 will be linked in with everything else and much more ( and needlessly) difficult to get to work. Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 19, 2012 Share Posted March 19, 2012 I think the only thing different is the bellhousing on the TD5 has an extra hole for the CPS? I've also always heard that you have to swap the gearbox over too, but I just don't see why really :/ Granted, I've never taken a look at a TD5 one. If I ever find a cheapo TD5 it's going into my RRC Quote Link to comment Share on other sites More sharing options...
davyd8899 Posted March 19, 2012 Author Share Posted March 19, 2012 Given that i need a td5 box, the early td5 only had high and low range and no diff lock, just tc. Given thats the set up i get can get, will my transfer box bolt onto the back Of this td5 box? Quote Link to comment Share on other sites More sharing options...
Stevie D Posted March 19, 2012 Share Posted March 19, 2012 As far as I know yes from previous research - the r380's are different - as stated ^^^^ the bell housing is longer as is the input shaft / different / longer. The parts for the cdl is just missing and early ones can depending on the casing used be retrofitted. Steve Quote Link to comment Share on other sites More sharing options...
nicks90 Posted March 20, 2012 Share Posted March 20, 2012 as said above, us your transfer box. its all there and set up. get the engine and gearbox from the donor disco and the wiring loom from a defender and then start scratching your head - throwing bits around the garage - asking millions of questions on here - have fun! Quote Link to comment Share on other sites More sharing options...
Ian300 Posted June 16, 2022 Share Posted June 16, 2022 Hoping someone still looks at old posts. When you fitted the td5 in are the engine mount interchangeable or did you cut the mounts of the td5 chassis and weld them back in the tdi Quote Link to comment Share on other sites More sharing options...
EeEk Posted August 21, 2022 Share Posted August 21, 2022 On 6/16/2022 at 5:50 PM, Ian300 said: Hoping someone still looks at old posts. When you fitted the td5 in are the engine mount interchangeable or did you cut the mounts of the td5 chassis and weld them back in the tdi engine mounts are very different. The easy option would be to cut the brackets off what ever the engine come out of and weld them to the chassis. Quote Link to comment Share on other sites More sharing options...
