pugwash Posted August 21, 2006 Share Posted August 21, 2006 Do all lights on a vehicle need to be "E" marked to pass SVA? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 21, 2006 Share Posted August 21, 2006 I am pretty sure that the answer to this will almost certainly be "yes"Jim....... Quote Link to comment Share on other sites More sharing options...
02GF74 Posted August 22, 2006 Share Posted August 22, 2006 no. but you need to prove they are up to the right standard - how you do that is anyone's guess - havingthe e-mark makes it easier. Quote Link to comment Share on other sites More sharing options...
filthy boy Posted August 22, 2006 Share Posted August 22, 2006 Do all lights on a vehicle need to be "E" marked to pass SVA? The answer is NO. If the lights are e-marked then they are definitely passable. If they are not e-marked then they must be of equivalent brightness etc. So if you have non e-marked lights you will have to prove to the examiner that they are equivalent. FB Quote Link to comment Share on other sites More sharing options...
pugwash Posted August 22, 2006 Author Share Posted August 22, 2006 The answer is NO.If the lights are e-marked then they are definitely passable. If they are not e-marked then they must be of equivalent brightness etc. So if you have non e-marked lights you will have to prove to the examiner that they are equivalent. FB hey FB that's what i understood from the SVA manual i have pirloined, but i wasn't sure. Wonder how you prove that they are of equivalent brightness- do you think a manufacturers spec sheet would do the job? I want to replace my rear lights with LED bits sourced from the US as i just can't find a good range of LEd lights in the UK! I anyone wants a PDF of the testers manual then let me know and i will see if i can post it somewhere. cheers Jim Quote Link to comment Share on other sites More sharing options...
fisha Posted August 22, 2006 Share Posted August 22, 2006 Are the lights from over the pond DOT approved? If so, you could possible persuade the tester than the DOT approval is of an appropriate equivalent standard to an e-mark. Quote Link to comment Share on other sites More sharing options...
pugwash Posted August 22, 2006 Author Share Posted August 22, 2006 Are the lights from over the pond DOT approved?If so, you could possible persuade the tester than the DOT approval is of an appropriate equivalent standard to an e-mark. yeah they are DOT approved- but i didn't know if DOT approval from the US had any relevance to the DOT in the UK? or is DOT approved always taken to mean US DOT? Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted August 22, 2006 Share Posted August 22, 2006 yeah they are DOT approved- but i didn't know if DOT approval from the US had any relevance to the DOT in the UK? or is DOT approved always taken to mean US DOT? what you do which is what wildcat do is to build the vehicle using "stock" parts. Once SVa'd they remove and change everything including the dashboard to the customers spec. p Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 22, 2006 Share Posted August 22, 2006 "E" I er "E" I Ooh ? Coat yes ok I'm leaving ....don't be rough Nige Quote Link to comment Share on other sites More sharing options...
michael calvert Posted August 22, 2006 Share Posted August 22, 2006 what sort of led lights do you want, abiot cumbersome but dont they do those 'hamburger' rear lights for commercials in LEDs option wjhich have brake or side at top indicator accross middle and side or brake at bottom??? (round) Quote Link to comment Share on other sites More sharing options...
evil90 Posted August 22, 2006 Share Posted August 22, 2006 what sort of led lights do you want, abiot cumbersome but dont they do those 'hamburger' rear lights for commercials in LEDs option wjhich have brake or side at top indicator accross middle and side or brake at bottom??? (round) They are called Continentals you can get them from DURITE agents last time i came across them they were about 60 quid but are very good especially if you can recess them and put some kind of guard on them Frank Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 22, 2006 Share Posted August 22, 2006 NAS type lamps are available in LED. They are fitted to busses so I guess that they are OK. Chris Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 22, 2006 Share Posted August 22, 2006 Legal: http://www.flexible-lamps.co.uk/Catalogue/Products/756.htm NAS type: http://www.flexible-lamps.co.uk/Catalogue/Products/837.htm Some stuff here: http://www.flexible-lamps.co.uk/Downloads/...ure%2004-05.pdf Any truck place can order Rubbolite/Flexible-lamp stuff. Chris Quote Link to comment Share on other sites More sharing options...
