Davo Posted February 28, 2017 Share Posted February 28, 2017 The "G" usually means Genuine, but as far as I'm concerned, if Turner Engineering uses something, then that's what I get. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 28, 2017 Share Posted February 28, 2017 G = Genuine, or more likely OEM. If turner are selling something, I would be tempted to get that, they do know what they are doing... Quote Link to comment Share on other sites More sharing options...
Daan Posted March 1, 2017 Author Share Posted March 1, 2017 The current seal is genuine (see picture with the box), bought from the landrover dealer. It does not have the 'G' added if you buy it of landrover. It works ok so far, but not many miles done. The money spent on genuine parts is certainly worth it in this situation. Daan Quote Link to comment Share on other sites More sharing options...
DC_ Posted March 1, 2017 Share Posted March 1, 2017 Yeh I found if you put G at the end of the part number, it doesn't mean much. I've ordered the dowty seal from turner, it's pricey but I'm hoping it'll last a while. Clutch and gaskets still to be ordered, bit more research to find out what I actually need in total. ?? Quote Link to comment Share on other sites More sharing options...
Prith Posted May 23, 2017 Share Posted May 23, 2017 I fitted a new Red Oil seal when I was replacing the clutch bearing and now she is leaking a lot. How is this possible with a new seal. Should I have used the Green one instead? Quote Link to comment Share on other sites More sharing options...
DC_ Posted May 25, 2017 Share Posted May 25, 2017 I'm not familiar with the red seal? I could only find the ones mentioned on this thread. Comparing the "turners" seal to one off ebag, there did appear to be a quality difference. So far so good, I'm just back from a 1000km trip and no oil is leaking from the bellhousing so it's did a good job. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted May 26, 2017 Share Posted May 26, 2017 I only use Payen or Elring, generally the latter and then I order form the manufacturer. Too many cheap copies in well forged boxes around now Quote Link to comment Share on other sites More sharing options...
