L835 Posted April 10, 2012 Share Posted April 10, 2012 I do know that it's when steel and water meet! But, why do defender bulkheads rust in the same places, ie around the screen hinge? Is it water entering from the bulkhead/screen joint, through the hinge holes, thrown up from the wheels (unlikely) or all three? The reason I ask is that my drivers door top hinge and the bulkhead are no longer in a relationship! The previous owners repair - filler foam! has finally given out. Fortunately I have a scrap 90 with a pretty good bulkhead, only a few minor holes in the usual places, and on the top where the screen sits. It's being repaired, and I am considering having it galvanised too. As its such a long job to swap the bulkheads over I'd rather only do it once, any thoughts on how to stop it rusting from within? Many thanks Richard Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 10, 2012 Share Posted April 10, 2012 Galv it !! Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 10, 2012 Share Posted April 10, 2012 Galv is is the preferred option for longevity, but filling it to the brim with cavity wax etc. is a good alternative. It rusts because the water gets in through the windscreen seal, screen frame to bulkhead seal, and hinge bolt holes, and then sits their making it nice and damp. It's an atrocious design, with multiple sheets of steel overlapping and spot-welded, followed by poor seam-sealing that once degraded allows water into the joints at which point it's game over. Quote Link to comment Share on other sites More sharing options...
simonr Posted April 10, 2012 Share Posted April 10, 2012 I think Land Rover include the rust in the factory! Galvanizing is the only solution that will work long term. None of the other methods will coat the inside of the bulkhead effectively - so if you only plan on doing it once, it's the only option. Si Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted April 10, 2012 Share Posted April 10, 2012 Based on the fact the galving is normally done to a used bulkhead how good is galv on hidden rust? I know they get dipped in acid first to clean but if there is still rust left will the fact the galv is preventing further oxygen reaching it stop the spread of rust? or is it going to eat it's way back out? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 10, 2012 Share Posted April 10, 2012 - Water wicking into joints - Mud collecting & holding moisture in hard-to-reach/clean places - The fact that no-one ever properly cleans the hard-to-reach places Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted April 11, 2012 Share Posted April 11, 2012 I got mine plated for £40 Quote Link to comment Share on other sites More sharing options...
L835 Posted April 11, 2012 Author Share Posted April 11, 2012 Local galv place quoted £95+vat. Need to get it plated and paint removed first. When I collected my trailer from Ifor williams, they told me that the galv was stronger than the steel in the chasis! I know what will happen! while it's off I might as well rewire, paint chasis.......! Quote Link to comment Share on other sites More sharing options...
tedsmart Posted April 11, 2012 Share Posted April 11, 2012 It also might be all the salt the council put on the road! Sorry not smug at all, just can't believe the condition of the 1996 110 that I bought in Brisbane, hardly any rust to speak of other than in the usual footwell places! You watch it'll now fall to pieces!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
