dirtyninety Posted May 7, 2012 Share Posted May 7, 2012 Just a quick one, obviously the serp 3.9 is a superior than the older rover v8's. But what year of discovery/range rover did then first appear in? also, what differences do they have to an older vee belt 3.9? thanks in advance! Quote Link to comment Share on other sites More sharing options...
stuck Posted May 7, 2012 Share Posted May 7, 2012 Why is a Serp three.9 (bloody keyboard!) better than an older three.9?! Didn't think the blocks were cross-bolted until the four.0 from the P thirty 8? Going to introduce this laptop to my 110 now Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 7, 2012 Share Posted May 7, 2012 Why is a Serp three.9 (bloody keyboard!) better than an older three.9?! Didn't think the blocks were cross-bolted until the four.0 from the P thirty 8? Going to introduce this laptop to my 110 now time for a new laptop I think Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 7, 2012 Share Posted May 7, 2012 Only differences if it's a 3.9 is are belts and a better oil pump. The 4.0 was the cross-bolted one, they just re-named it 4.0 for the American market as the J**p was sporting a 4.0, and that's more numbers than a 3.9, obviously. Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted May 7, 2012 Author Share Posted May 7, 2012 So the 4.0 is the engine i should be looking for, so what year did they come in/out? also presuming these would mate up to a v8 LT85 or a v8 r380? Quote Link to comment Share on other sites More sharing options...
stuck Posted May 7, 2012 Share Posted May 7, 2012 If you can go for a four.6. Unsure on the year but it will certainly mate up to a R three 80, mine's connected to one Quote Link to comment Share on other sites More sharing options...
zim Posted May 7, 2012 Share Posted May 7, 2012 LOL Mick - your keyboard is quality ! I've got a 4.2 that isn't a serp nor is it cross bolted. My 1995 4.6 is serp and cross bolted. G Quote Link to comment Share on other sites More sharing options...
task Posted May 7, 2012 Share Posted May 7, 2012 The "intermediate" Serpentine engines were fitted to the Softdash Range Rover Classic and the 300-shape Discovery. They had the later oil-pump but also still had the distributor. I believe some "meat" was added to the main bearing caps at this stage, might be wrong. These engines also used the superior composite gaskets and the outer row of bolts were deleted from the heads. After this, the 4.0 came along fitted to the P38/Disco2 and the 4.6 in the P38 (and export Disco2). This has no distributor and a slightly different front cover to the previous serpentine engine. This is also where the larger crank diameter and cross bolting came in. From memory, so might be wrong Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 7, 2012 Share Posted May 7, 2012 Why is a Serp three.9 (bloody keyboard!) better than an older three.9?! Didn't think the blocks were cross-bolted until the four.0 from the P thirty 8? Going to introduce this laptop to my 110 now OT but you can normally pick up laptop keyboards on ebay and they are pretty easy to change Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted May 7, 2012 Author Share Posted May 7, 2012 If you can go for a four.6. Unsure on the year but it will certainly mate up to a R three 80, mine's connected to one LOL Mick - your keyboard is quality ! I've got a 4.2 that isn't a serp nor is it cross bolted. My 1995 4.6 is serp and cross bolted. G The "intermediate" Serpentine engines were fitted to the Softdash Range Rover Classic and the 300-shape Discovery. They had the later oil-pump but also still had the distributor. I believe some "meat" was added to the main bearing caps at this stage, might be wrong. These engines also used the superior composite gaskets and the outer row of bolts were deleted from the heads. After this, the 4.0 came along fitted to the P38/Disco2 and the 4.6 in the P38 (and export Disco2). This has no distributor and a slightly different front cover to the previous serpentine engine. This is also where the larger crank diameter and cross bolting came in. From memory, so might be wrong Cheers lads, i'll keep a look out for a later disco 2 V8 then. arnt vapour builds brilliant! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 9, 2012 Share Posted May 9, 2012 V8 P38's are cheap as chips too. Quote Link to comment Share on other sites More sharing options...
barriesheene Posted May 18, 2012 Share Posted May 18, 2012 Got a nice 4.6 gas converted you can have for £1295 . Quote Link to comment Share on other sites More sharing options...
