PAS boxes and ball joints
darthdicky
I've got a 4 bolt steering box with a drop arm without a balljoint on it. I bought a balljoint kit to put on it but can't figure out how it goes together?
Best diagram I've found is here: Exeter4x4
These are the bits I've got
But the arm is different to that shown in the diagram
Is this the right kit for this kind of arm? If so, which side is the joint pushed through from - the top or the bottom?
Cheers,
Richard
I thought they did use a TRE, not had one so could well be wrong though.
The drop arm can be swapped, assuming you can get it off the box, this is the only way to keep the swan neck.
If you use that drop arm you will need a mount, clamp or weld on, fitting to the drag link for the damper.
Bugger. Just been for a look and the nut on the bottom of my box is larger than 32mm, but the one on the PAS box is about 32mm. Guess how big my socket set goes up to!
Wondering whether to take both boxes off and over to a garage to get the arms swapped over, might save me a load of hassle...
Richard
Richard,
I converted my Defender swan neck and ball joint arrangement to the version you picture above. I was sick of replacing the joints because the boot comes off, they fill with mud and hold it.
I bought a Disco drop arm (as you already have) and a Disco front sumo bar. Screw a TRE into both ends and bob's your uncle, and they're easier to change to boot.
A TRE? There's a whole forrest of the buggers here! Wassat then?
TRE - usaul abbreviation for Tack Rod End.
basically a bolt with a taper with a ball on the end. the ball is spring loaded and sits inside a housing with a threaded tube or another threaded end coming out of the side. that part screws onto a steering arm or track rod.
as thousand words could be saved by 1 picture.
Dicky,
I've got a 4 bolt defender type drop arm floating around my workshop that i fitted a new balljoint kit to before discovering it wouldnt fit to a 6 bolt box - d'oh!
Yours for the cost of the balljoint kit if you want it - as I say its never been on the vehicle since the kit was fitted.
That makes it a nuts a bolts job to fit to your truck!
Cheers
Jon
Cheers guys, I think I'll stick with the Defender arrangement. I've taken the manual box and the PAS one down to the garage and they're going to have a go at swapping the drop arms over. They'll also fit the new balljoint kit as I've got too much other stuff to do at the moment.
Cheers for the offer Jon, but I'm hoping I've got the right arm on the current box and they'll swap easily.
Richard
On second thoughts, I'm wondering whether I might need that arm Jon...
Looking through a parts manual I found on the net it seems that I have a Gemmer manual box, and the PAS box is an Adwest. Gemmer make the 6 bolt one and if you found that they don't swap, I have a feeling the two I have are different and therefore won't fit.
Other alternative is to go for some Sumo bars and a relocation kit, but I wasn't planning on splashing out on them yet. Anyone got a picture of the relocation kit fitted as I want to make sure it'll clear my winch shafts?
Richard
Dicky,
Correct - I just checked the parts book and the drop arm for a gemmer box is a different part number than for a 4 bolt box. If you'd had the adwest manual box it would have swapped over.
Well you know where it is if you want it. Probably wont be cheap to post though cause its pretty weighty!
Jon
So much for a cheap conversion - I've just splashed out on some Sumo bars :o
Garage had huge trouble getting the old arm off so I've decided to keep the disco one and use TREs.
To replace all of them now I guess I need 4 of them? 2 RTC 5870 and 2 RTC 5869? Can you get greasable ones and are they any good?
Which way up does the joint go on the drop arm? Sumo website seems to show it with the joint below the arm which doesn't seem too well protected?
Cheers,
Richard
It indeed goes below the arm. That way the 'ball' is in the same place but the gubbins that supports it is higher and out of the way. If the ball was above the arm (it'd hit stuff and the taper wouldn't fit and) you'd get bump-steer because the drag link wouldn't be parallel to the panhard rod.
Now you just need four standard TREs (2x LH thread, 2x RH thread) and you can specify the greasable type when you buy them.
I used the original damper I think, with an eye at the o/s end. If I remember tonight I'll photograph it for you, I think it's a QT relocator bracket (but it doesn't fit well on my Sumoalike solid bars, I had to pack it out a bit).
Pin to eye converter is easy though - bend a piece of strip into a U shape and drill a hole in each part of the U - three holes in total. Bolt that to your relocation bracket, and bolt the damper eye inside the U.
