need4speed Posted February 11, 2013 Share Posted February 11, 2013 Ok so im in the middle of modifying my main harness to suit my needs. Im having to remove a lot of stuff that i dont need and therefore making it a lot smaller/neater. I was wondering how people go about removing the big rubber bungs that go into the bulkhead. Both of them seem very tight to the point that they dont seem to want to move. Also, can these be purchased separately? I seem to remember seeing them on ebay but last time i looked couldnt see them? Quote Link to comment Share on other sites More sharing options...
fireblade7 Posted February 11, 2013 Share Posted February 11, 2013 i also saw them on ebay for sale i rebuilt a 90 with them on and pushed in ok mybey just a matter of screwdriver pushed inbetween rubber and bulkhead regards mike Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 11, 2013 Author Share Posted February 11, 2013 No i think you misunderstand. I can get them in and out of bulkhead easy enough. Its removing them from harness i mean. So i can remove wires from loom properly.. Quote Link to comment Share on other sites More sharing options...
Maverik Posted February 11, 2013 Share Posted February 11, 2013 Boom... http://www.ebay.co.uk/itm/200681112419?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 And you just have to undo the tape and unwrap the bundle of wires, if you're using a knife... you do it very carefully indeed... Mav Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted February 11, 2013 Share Posted February 11, 2013 If you're just removing wires, could you not leave it on and just slide it up and down to remove tape and retape etc. As it could be a bit of a pain to push all the connectors through. Just a thought. Steve P.S. I don't know what its started to write out from the right? Quote Link to comment Share on other sites More sharing options...
Tanuki Posted February 11, 2013 Share Posted February 11, 2013 Heat the bungs in some hot water - this softens them. Then use washing-up-liquid as a lubricant. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted February 11, 2013 Share Posted February 11, 2013 Bit of silicoln grease Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 11, 2013 Author Share Posted February 11, 2013 Thanks for all the advice chaps I will try removing the wires without removing them if i can once ive removed all the tape. If that doesnt work i'll try the silicon grease as Les suggests. Phil Quote Link to comment Share on other sites More sharing options...
Three Blades Posted February 12, 2013 Share Posted February 12, 2013 When you get around to recovering the loom, I suggest that you see if you can find an alternative to the corregated split cover that is used as standard. I suffered from some rubbing between the corregations and the cables that caused a nasty short circuit. Wrap it up with loom tape (non stick insulation tape) and then put it into something else as a main cover. I ended up using a rubber water pipe as it seemed to fit the bill and offered even, flexible protection. However it has not been on for long so I cannot comment on its longevity. Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 12, 2013 Author Share Posted February 12, 2013 Fair point. I was actually going to just use loom tape, then finish it off with heatshrink. Quote Link to comment Share on other sites More sharing options...
NickMc Posted February 12, 2013 Share Posted February 12, 2013 Yeah i'd wrap the loom and find something other than the ribbed conduit, it's starting to cause a world of pain on the older td5's now Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted February 13, 2013 Share Posted February 13, 2013 Think I've got a couple of the bungs in the garage from my loom capers. Yours for the postage if you want em. Rob Quote Link to comment Share on other sites More sharing options...
