Landy-Novice Posted April 8, 2013 Share Posted April 8, 2013 hello. after replacing the bulkhead top corners, i need to re-drill the holes out for the windscreen hinges. i cant just drill from behind as there's not much there. so as picture says, i need measurements for A, B, C and D. please admire my awesome paint skills Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted April 8, 2013 Author Share Posted April 8, 2013 almost 35000 members and not one answer? someone must have a spare bulkhead in the garage the can take measurements from. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 9, 2013 Share Posted April 9, 2013 A: 36mm B: 35mm C: 15mm D: 55mm All measurements subject to landrover tolerance of +/- 5mm Quote Link to comment Share on other sites More sharing options...
mikec Posted April 10, 2013 Share Posted April 10, 2013 A: 36mmB: 35mmC: 15mmD: 55mmAll measurements subject to landrover tolerance of +/- 5mm Yep I got pretty much the same. Quote Link to comment Share on other sites More sharing options...
Paul Brann Posted November 21, 2020 Share Posted November 21, 2020 On the same theme, does anyone please have the dimension between the bolt to chassis mounting holes - my guess is that it's about 1500mm but I really need to know for certain before I end up with somehting that just won't fit, even with the Land Rover approved method of fitment. Very many thanks, Paul Brann Quote Link to comment Share on other sites More sharing options...
steve b Posted November 21, 2020 Share Posted November 21, 2020 1510-1515mm I think , can check one tomorrow to be sure cheers Steve b Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 21, 2020 Share Posted November 21, 2020 I can check tomorrow too if Steve doesn't. Also matched up nicely with my chassis without any issues. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted November 22, 2020 Share Posted November 22, 2020 I just measured the diameter of the holes ... they are 25 mm 😇 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 22, 2020 Share Posted November 22, 2020 21 hours ago, Paul Brann said: On the same theme, does anyone please have the dimension between the bolt to chassis mounting holes - my guess is that it's about 1500mm but I really need to know for certain before I end up with somehting that just won't fit, even with the Land Rover approved method of fitment. Very many thanks, Paul Brann Realised I’ve got a gearbox in the way of measuring the one on the chassis, but the spare bulkhead measures up at 1500mm centre to centre. Quote Link to comment Share on other sites More sharing options...
steve b Posted November 22, 2020 Share Posted November 22, 2020 The one in my workshop is 1500mm too ~ 59" in old money . Quote Link to comment Share on other sites More sharing options...
Dharge1968 Posted April 25, 2021 Share Posted April 25, 2021 On same theme does anyone know the measurement between the windscreen bolt down to the bulkhead to chassis bolt? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 26, 2021 Share Posted April 26, 2021 On 4/25/2021 at 11:08 AM, Dharge1968 said: On same theme does anyone know the measurement between the windscreen bolt down to the bulkhead to chassis bolt? Talking series I presume? Quote Link to comment Share on other sites More sharing options...
