Don Del Posted August 28, 2013 Share Posted August 28, 2013 Hi, I have a '99 V8 110 Station Wagon fitted with an R380 gearbox and an LT230TE transfer box. While checking underneath I noticed a slight oil leak coming from the joint between the gearbox and the transfer box. I haven't checked the oil levels but will do so tomorrow. Any suggestions as to the possible cause(s) of the leak? Cheers, Del Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted August 28, 2013 Share Posted August 28, 2013 This post from another forum helped me with a similar problem The hard part is finding the source of the leak, fixing it usually quite easy. Where exactly is the oil appearing? what type of oil is it? how much oil is leaking?. A leak from the flywheel drain hole can come from 3 likely sources - 1) The engine is loosing oil, probably from the crankshaft rear seal, that oil is usually black or dark brown in colour and tastes like engine oil . Not too bad if the leak is small, say approximately one spoonful of oil per day. 2) The main gearbox is loosing oil through the input shaft seal, that oil may, be red in colour, again a minor leak is not the end of the world but if not fixed it could eventually turn embarrasingly expensive. 3) The clutch slave cylinder is leaking, the oil may be light/golden brown colour, relatively easy to fix but if you loose more than a couple of spoonfuls of oil you will have no clutch . A leak from above the top of the gearbox may simply be coming from the engine rocker cover and is easy enough to repair/replace. Quote Link to comment Share on other sites More sharing options...
Don Del Posted August 28, 2013 Author Share Posted August 28, 2013 This post from another forum helped me with a similar problem The hard part is finding the source of the leak, fixing it usually quite easy. Where exactly is the oil appearing? what type of oil is it? how much oil is leaking?. A leak from the flywheel drain hole can come from 3 likely sources - 1) The engine is loosing oil, probably from the crankshaft rear seal, that oil is usually black or dark brown in colour and tastes like engine oil . Not too bad if the leak is small, say approximately one spoonful of oil per day. 2) The main gearbox is loosing oil through the input shaft seal, that oil may, be red in colour, again a minor leak is not the end of the world but if not fixed it could eventually turn embarrasingly expensive. 3) The clutch slave cylinder is leaking, the oil may be light/golden brown colour, relatively easy to fix but if you loose more than a couple of spoonfuls of oil you will have no clutch . A leak from above the top of the gearbox may simply be coming from the engine rocker cover and is easy enough to repair/replace. The oil is coming from either the gearbox or the transfer box and is leking from the mating face. Quote Link to comment Share on other sites More sharing options...
dave88sw Posted August 28, 2013 Share Posted August 28, 2013 If it's red, it's from the gearbox and probably the rear mainshaft oil seal (pig to change). If it's yellow, it's ep90 and coming from the transfer box, probably the input seal, a bit of a pig to change as the transfer box has to be removed but not nearly as bad as the gearbox seal. Hopefully that helps a little. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted August 28, 2013 Share Posted August 28, 2013 Check your breathers are clear,that might be rhe cause before changing seals Quote Link to comment Share on other sites More sharing options...
Don Del Posted August 29, 2013 Author Share Posted August 29, 2013 Thanks for the input. The oil is not red so it looks as though it is the seal on the input to the transfer box. i will check the breather but knowing my luck I am not holding my breath! Cheers, Del Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted August 29, 2013 Share Posted August 29, 2013 Only one oil leak, and it's a Land Rover! I don't believe it. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 30, 2013 Share Posted August 30, 2013 Could be the intermediate shaft o-ring as well... Quote Link to comment Share on other sites More sharing options...
