landroversforever Posted September 13, 2013 Share Posted September 13, 2013 Can anyone confirm what line of VDO gauges are used as standard in the TD5 era defenders? I want to get new gauges for the centre console that match. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 13, 2013 Share Posted September 13, 2013 VDO Siemens make them but they're not a standard range. Closest would probably be the Vision ones. Quote Link to comment Share on other sites More sharing options...
western Posted September 13, 2013 Share Posted September 13, 2013 the VDO Vision range as Retro says are the best match,https://www.merlinmotorsport.co.uk/s/instruments-gauges/vdo/vdo-cockpit-vision-gauges I believe your nearest stockist is https://www.merlinmotorsport.co.uk/s/instruments-gauges/vdo/vdo-cockpit-vision-gauges at Castle Coombe race circuit near Chippenham. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 14, 2013 Share Posted September 14, 2013 If you can find them, VDO did an older range of gauges which are a better match for the Td5 units. This is one I picked up off eBay a little while ago: It has the same blue/red ends of the scale and a white needle so I picked it up with the aim of putting it in the 90 to replace the Td5 gauge. Was going to get a new one from the Vision range but the match wasn't good enough and I figured it would annoy me! This isn't perfect but at least the colours are the same. It's stamped 1985 so that gives you an idea of the era. Think the chap I bought this off said it came out of a Triumph or something like that, but it may have been aftermarket so who knows. The VDO number is shown there but no idea whether you could still get it from anywhere. Mine came with a sender to match. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 15, 2013 Author Share Posted September 15, 2013 I think the problem I'm going to have either way is finding a matching set of gauges. Can't find any range that has all the ones I'm after I need: Volts (x2) EGT Air Pressure (Tank pressure for OBA) Boost Possibly Oil Pressure Quote Link to comment Share on other sites More sharing options...
western Posted September 15, 2013 Share Posted September 15, 2013 as a alternative these http://www.madman.co.za/index.php/products/engine-monitoring-systems can do multiple display reading from various sensors, don't know what the exchange rates/prices are like. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 15, 2013 Share Posted September 15, 2013 With that many additions where are you planning to mount them ? What I'm wondering is that if they are in a stand alone console - and they all match each other and look pretty close to the standard one in their standard locations .... Then all may be well ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 15, 2013 Share Posted September 15, 2013 Why 2 voltage, Ross? Quote Link to comment Share on other sites More sharing options...
Ash.Witty Posted September 15, 2013 Share Posted September 15, 2013 Vdo do all of the above but you will have to order from the USA, stack are very expensive but very good and auto meter gauges are cheap and cheerful. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 15, 2013 Share Posted September 15, 2013 It'll be like the Enterprise with all those Ross! Are you sure you want all that information at you all the time? I used to have a voltmeter in mine and got rid of it fairly sharpish as I just found myself watching it and worrying over the smallest changes. It took all the fun out of driving it, and no doubt would be even worse with an oil pressure gauge or the like. Ignorance is bliss I find. Perhaps I'm slightly more likely to blow the engine up or the like yes but at least I can now enjoy driving it until then Quote Link to comment Share on other sites More sharing options...
western Posted September 15, 2013 Share Posted September 15, 2013 It'll be like the Enterprise with all those Ross! a bit like my cab then Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 15, 2013 Share Posted September 15, 2013 Yours is like two enterprises Ralph ... Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 15, 2013 Share Posted September 15, 2013 Ralph, yours is like a 'Learner' Enterprise with dual controls ... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 15, 2013 Author Share Posted September 15, 2013 With that many additions where are you planning to mount them ?What I'm wondering is that if they are in a stand alone console - and they all match each other and look pretty close to the standard one in their standard locations .... Then all may be well ? In the centre console. The stereo is going and being replaced by a unit in the roof. Why 2 voltage, Ross? One for each battery. Still to this day, even after stripping all the wiring out, do not know which battery my old gauge was showing! Vdo do all of the above but you will have to order from the USA, stack are very expensive but very good and auto meter gauges are cheap and cheerful. I'll have a look, thanks . Stack gauges are gorgeous, especially their white faced ones. As you say though, very spendy! It'll be like the Enterprise with all those Ross! Are you sure you want all that information at you all the time? I used to have a voltmeter in mine and got rid of it fairly sharpish as I just found myself watching it and worrying over the smallest changes. It took all the fun out of driving it, and no doubt would be even worse with an oil pressure gauge or the like.Ignorance is bliss I find. Perhaps I'm slightly more likely to blow the engine up or the like yes but at least I can now enjoy driving it until then That's partly why I'm not 100% sure on the oil pressure one. The rest is all useful. I've never found myself looking and worrying other than EGTs climbing up during a long incline. One reason for the oil pressure gauge would be to be able to better monitor the oil situation... I've had the oil light flickering several times when the engine is warm and sat on tickover. Ralph, yours is like a 'Learner' Enterprise with dual controls ... so true! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 15, 2013 Share Posted September 15, 2013 Are your batteries in parallel? Then they will read the same. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 15, 2013 Author Share Posted September 15, 2013 Only when the split charge is working. I'd have though it would also depend on the load on each battery too? Quote Link to comment Share on other sites More sharing options...
MBE_NZ Posted September 15, 2013 Share Posted September 15, 2013 I'm after a EGT to replace the clock in the dash for a TD5 - so would be interested in your findings Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 16, 2013 Share Posted September 16, 2013 Only when the split charge is working. I'd have though it would also depend on the load on each battery too? Well you would hope that the split charge would be working when the engine is running, so that'll be 99.9% of the time. Voltage won't vary differently by load if the split charge is working, as they are still connected in parallel, and will average the voltage between them. The only time I can see them being useful is when the engine is off. Quote Link to comment Share on other sites More sharing options...
