smallfry Posted November 13, 2013 Share Posted November 13, 2013 About a fortnight ago, my clutch started dragging a bit..............not quite disengaging properly, causing the gears to clash slightly. So I thought I would take the top off the master cylinder to check the fluid, only to find that was not a drop in sight. Completely empty. I filled it up again, but I couldnt be bothered to bleed it as it was getting dark, however, the clutch then seemed to be working OK. A few days later I looked again, and the reservoir is empty once again, so I filled it up, and went out in the Landy for the afternoon with no issues. Repeat another three times. Now, there is no fluid running down the back of the pedal or in the footwell, and there are no puddles underneath, and nor is there any dripping from the bellhousing. So my question is, where is it going ? I cant see any leaks at all, so I can only conclude that someone is syphoning it off............... Any ideas ? Quote Link to comment Share on other sites More sharing options...
discomikey Posted November 13, 2013 Share Posted November 13, 2013 you got a wading plug or extended breathers in your FW housing? Quote Link to comment Share on other sites More sharing options...
smallfry Posted November 13, 2013 Author Share Posted November 13, 2013 you got a wading plug or extended breathers in your FW housing? No, and no Quote Link to comment Share on other sites More sharing options...
duncmc Posted November 14, 2013 Share Posted November 14, 2013 Have you got a leak from the pipe somewhere along it length? It could then be dripping from the pipe and running somewhere else, maybe even pooling in an area, or absorbed into some sound proofing on the bulkhead? Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 14, 2013 Share Posted November 14, 2013 hmm its not magic so it will be going somewhere. I suggest you have a look a little closer. it could be evaporating off before you get chance to see it.... so look for snail trails and residue as to where it could possible have run. If the master is leaking then it can pool in the bracket space then overflows down the engine bay side of the bulkhead, not necessarily leak inwards. Quote Link to comment Share on other sites More sharing options...
Rangie46 Posted November 14, 2013 Share Posted November 14, 2013 Had the same issue myself and was the slave cylinder leaking into the bell housing and then getting burnt off by clutch no signs of fluid on the ground, you defo have a leak somewhere, if it where me for good measure I would replace master and slave as they are not that expensive. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted November 14, 2013 Share Posted November 14, 2013 For the reservoir to be emptying itself in a few days I would expect to see a pretty obvious trail if there was a hose/pipe leak. However IME, slave cylinder failure normally dumps the fluid into the clutch housing, and then the fluid runs out of the drain hole. If the inside of your bellhousing is caked in mud or other muck, it may be absorbing the lost fluid... Failing that, do you have any local friends comedians that may be having a laugh at your expense? Can your bonnet be opened from outside the cab (early spec)? Quote Link to comment Share on other sites More sharing options...
discomikey Posted November 14, 2013 Share Posted November 14, 2013 see if you can get some UV containing fluid, im sure you can, then after you have lost that take it into a dark garage and go over it with a UV light? Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 14, 2013 Share Posted November 14, 2013 see if you can get some UV containing fluid, im sure you can, then after you have lost that take it into a dark garage and go over it with a UV light? now that's thinking outside the box... I like it! maybe a little overkill but I like it all the same. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 14, 2013 Share Posted November 14, 2013 You could also check your mates hands in case it really is comedians at work Quote Link to comment Share on other sites More sharing options...
smallfry Posted November 15, 2013 Author Share Posted November 15, 2013 Many thanks for your replies and input, that has all be a bit of a mystery ! I DID wonder if the leak was inside the bellhousing and was being absorbed by dust/mud/whatever inside, but figured that as I had put so much in that SURELY something would have leaked out by now................ Anyway, had a torch all over it but could see nothing, tried running some kitchen roll all over the system, up inside the pedal box, and all over the suspected *ritpart slave cylinder (PO, not me) but still nothing, except for some engine oil, which of course looks, smells, and feels completely different. Already decided to replace the whole lot and have done with it, as it will be the ideal opportunity to install me spring assisted pedal, but I absolutely HATE not being able to find out what the problem was, because you don't learn anything from it. Was just about to pack up for the evening, when neighbour arrived home and asked what the problem was THIS TIME, as she is always asking why I don't buy a decent vehicle like her Audi blah blah blah..............Its a standing joke thing, as the Audi has come home on a truck twice, which of course I cant help but point out.................. While she was there I got her to hold down the clutch pedal while I looked underneath, and it was then that the problem hit me in the face..............literally. The jump hose has a tiny pinhole in it, and gives a fine spray which points directly down to the ground when the system is pressurised. When the pedal is released, it stops, and there is no evidence whatsover to be seen, except on closer inspection, a VERY small stain on the gearbox crossmember, and also the rear axle. I am still going to replace the lot though. Quote Link to comment Share on other sites More sharing options...
jbs Posted November 15, 2013 Share Posted November 15, 2013 Great to see you've found your problem. John Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 15, 2013 Share Posted November 15, 2013 Good effort! Quote Link to comment Share on other sites More sharing options...
