Souster Posted May 16, 2014 Share Posted May 16, 2014 Just been messing under the centre seat. Found 2 wires with a spade terminal and 1 with a bullet connector. Anyone know what these are for? http://s905.photobucket.com/user/souster4/media/Mobile%20Uploads/2014-05/A677FA1A-7C68-40D1-BE70-10A28CDBF303.jpg.html Quote Link to comment Share on other sites More sharing options...
Souster Posted May 16, 2014 Author Share Posted May 16, 2014 Im sure one was a bullet connector. But after looking at the picture im not sure Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted May 16, 2014 Share Posted May 16, 2014 handbrake, diff lock, reverse? Quote Link to comment Share on other sites More sharing options...
discomikey Posted May 16, 2014 Share Posted May 16, 2014 what vehicle? my guess would be reverse light switch and diff lock switch? maybe an oil temp switch for the gearbox although unless its an auto i highly doubt that. Quote Link to comment Share on other sites More sharing options...
discomikey Posted May 16, 2014 Share Posted May 16, 2014 what model and age and what engine/gearbox configuration? if you could let us know what the wire trace colours are then that would go a long way to finding what they are Quote Link to comment Share on other sites More sharing options...
Souster Posted May 16, 2014 Author Share Posted May 16, 2014 Sorry. Its a 96 defender 300tdi truck cab. I dont think its the difflock switch, as that works fine. I havent got a hand brake light, so its a possibility Quote Link to comment Share on other sites More sharing options...
western Posted May 16, 2014 Share Posted May 16, 2014 clean the wires & post up the colour coding of each wire, then we can tell you what they are for more accurately. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted May 17, 2014 Share Posted May 17, 2014 They are for the Egr ecu which has been removed Quote Link to comment Share on other sites More sharing options...
Souster Posted May 17, 2014 Author Share Posted May 17, 2014 I'll have a look at the wire colours tonight then fellas. I didnt think the older models had Egr, thats why i wasnt sure Cheers Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted May 17, 2014 Share Posted May 17, 2014 The egr module has a multi plug, not individual wires..... See if any are live with engine running, if not, connect to earth and see what happens, dash lights etc.... Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 17, 2014 Share Posted May 17, 2014 It's not the reverse light as that's the 2 pin multi plug hidden in the dirt on top of the LT230. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 17, 2014 Share Posted May 17, 2014 I think two of them are for a gearbox oil temperature switch, connectors C219 and C269 Quote Link to comment Share on other sites More sharing options...
Souster Posted May 17, 2014 Author Share Posted May 17, 2014 It's not the reverse light as that's the 2 pin multi plug hidden in the dirt on top of the LT230. Is that the connector to the left of my thumb is the picture? Does that mean i have all the connections for the handbrake light? I'll have a look at the wire colours when i get back tonight. Cheers Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 17, 2014 Share Posted May 17, 2014 Yep, the big connector, it's black if you wipe the mud off. Quote Link to comment Share on other sites More sharing options...
Souster Posted May 17, 2014 Author Share Posted May 17, 2014 Bit of an update fellas, found the wire colours. One of the wires is grey with red tracer with a female spade terminal One is black with a female spade terminal The other is white with yellow tracer with a female bullet connector. All of which seem to come from similar location to the multi plug connector to the left of my thumb in the picture. Any ideas? Quote Link to comment Share on other sites More sharing options...
Souster Posted May 17, 2014 Author Share Posted May 17, 2014 Also, the black and grey/red tracer are wrapped in the same tape if that helps Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 17, 2014 Share Posted May 17, 2014 C219 is grey with red tracer according to the diagrams, doesn't list colours for c269 unfortunately. C219 is definitely gearbox oil temp switch Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 17, 2014 Share Posted May 17, 2014 White with a yellow tracer should have a spade connector for the hand brake, connector number C091 on the circuit diags. Quote Link to comment Share on other sites More sharing options...
Souster Posted May 17, 2014 Author Share Posted May 17, 2014 Thankyou mate. Just noticed on the diagram and westerns hand brake cable write up that the spade and bullet connector wire is missing. On further inspection, i have a hand brake switch also, the spade terminal has just broken off. Thanks for clearing things up Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 17, 2014 Share Posted May 17, 2014 Glad my ramblings helped Quote Link to comment Share on other sites More sharing options...
Souster Posted May 17, 2014 Author Share Posted May 17, 2014 Does anyone know if this hand brake switch can be used? Looks identical to the land rover one at half the price? http://www.ebay.co.uk/itm/Ford-Handbrake-Warning-Switch-24B30-/281229751854 Quote Link to comment Share on other sites More sharing options...
western Posted May 18, 2014 Share Posted May 18, 2014 Looks same as mine [genuine LR switch] http://forums.lr4x4.com/index.php?showtopic=1683 Quote Link to comment Share on other sites More sharing options...
Souster Posted May 18, 2014 Author Share Posted May 18, 2014 Looks same as mine [genuine LR switch] http://forums.lr4x4.com/index.php?showtopic=1683 I thought the same western. Think I'll give it ago, im a right tight arse ££ haha Quote Link to comment Share on other sites More sharing options...
