stobbie Posted July 9, 2014 Share Posted July 9, 2014 Hi, I've repaired a badly crash damaged Defender. I have replaced the chassis and front axle and bodyparts but didn't do any work at the engine because I couldn't see andy damaged parts. Today we've tried to start the engine for the fist time and it fired straight up (after standing for 6 months) but died after 20 seconds or so. Now the engine will cranck but does not fire. SDD doesn't show any DTC's. Does anyone hae an idea what could cause this? Quote Link to comment Share on other sites More sharing options...
Tanuki Posted July 9, 2014 Share Posted July 9, 2014 Has the impact-sensing thing [which shuts off the fuel-pump in the event of a crash] been reset? Quote Link to comment Share on other sites More sharing options...
stobbie Posted July 9, 2014 Author Share Posted July 9, 2014 No, I don't think a puma has an inertia switch? Should I hear the fuel pump in the tank run when I turn on the ignition? I hear nothing.. I'm not used to Puma's.. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 9, 2014 Share Posted July 9, 2014 The workshop manual says model year 12 yas an intertia switch, which year is this one? EDIT: Although the inertia switch should raise a DTC Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 9, 2014 Share Posted July 9, 2014 MY07 manual mentions an 'Inertia Fuel cut off Switch' so it looks like there is an inertia switch on both versions of the Puma Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted July 10, 2014 Share Posted July 10, 2014 Check the relays under the drivers seat and make sure they are fully seated and that there is no corrosion evident on the connections and sockets. Loose relays are a fairly common problem in vehicles that only get day to day use let alone one that has been involved in a shunt and then sat around for a bit. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted July 10, 2014 Share Posted July 10, 2014 Has an inertia switch by heater box. Andy Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted July 10, 2014 Share Posted July 10, 2014 I've never seen a chassis bent like that. What did it hit and how fast? Quote Link to comment Share on other sites More sharing options...
squaddiefox Posted July 10, 2014 Share Posted July 10, 2014 Something solid and quickly. Quote Link to comment Share on other sites More sharing options...
