tacr2man Posted August 9, 2014 Share Posted August 9, 2014 Has anyone tried using these as junction connectors when doing vehicle wiring ? http://www.ebay.co.uk/itm/25-WAGO-3-WIRE-LEVER-ELECTRIC-CABLE-CONNECTOR-FLEX-TERMINAL-BLOCK-WIRE-JOINER-/251294270587?pt=UK_BOI_Materials_Supplies_Electrical_ET&hash=item3a824e447b Quote Link to comment Share on other sites More sharing options...
henk Posted August 9, 2014 Share Posted August 9, 2014 for home installations this works as you have only a single wire, in a car with multi-wire this could be problematic Quote Link to comment Share on other sites More sharing options...
Edlen Posted August 9, 2014 Share Posted August 9, 2014 Worthwhile looking here http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php Quote Link to comment Share on other sites More sharing options...
Team Idris Posted August 9, 2014 Share Posted August 9, 2014 Yeh man, I was biggin' with the Wago's this morning on the van Practicality; Don't like what you just laid in?? Just flip the lever and change it. Ever had the screw connector come loose? Won't happen with a spring connector. Have you got one earth you want to split to 4? then 5way wago it. Consider it one up from a scotch-lock and one down from a proper crimped spade. But when all said and done, nothing is going to do better than a proper narrow brass crimp with a rubber shroud like the OE's use. If you use a 3 or a 5 way, use mini cable ties to bring the cables together tight in a group, to reduce wire fatigue. But this goes for screw connectors as well. If you're really worried, tin the ends of the wire, as the wago still grips well. Unlike screw connectors it is easier to connect 2.5mm with tiny wires than with any other method I've seen. Quote Link to comment Share on other sites More sharing options...
jimyd Posted August 10, 2014 Share Posted August 10, 2014 Not used these exact terminals, but use quite a lot of Wago parts at work. They are very good, never really get a problem with them, although always used in an enclosure. For vehicle wiring though you ideally need boot lace ferules on the cable ends first. Quote Link to comment Share on other sites More sharing options...
Adam001 Posted August 11, 2014 Share Posted August 11, 2014 That is a awful lot of money for something doing a simple job which freely allows moisture ingress. Simple and elegant yes, effective, not so much. I also can't see those little plastic levers putting much force on the wires compared to a crimp. Junction points I swear by proper well fluxed soldering on a large crimp connector. Lots of people hate soldering, but that's because of dry soldering. I have never had a joint fail. Having said this though, they would be great for test boards! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 11, 2014 Share Posted August 11, 2014 That style are used a lot for all sorts of things and seem pretty reliable, but I've not seen them used anywhere that's exposed to the elements or mechanical movement / vibration. I'm sure Wago would tell you their intended use, either on their website or technical hotline. They might say they work fine, or they might tell you it's a terrible idea and recommend something better. For junctions of multiple wires I either use standard crimp butt splices, solder & heat-shrink, or a commoning terminal block / bus bar depending on the exact nature of the job at hand. Quote Link to comment Share on other sites More sharing options...
HoSS Posted August 11, 2014 Share Posted August 11, 2014 ^ What he said. Quote Link to comment Share on other sites More sharing options...
94Discovery Posted August 12, 2014 Share Posted August 12, 2014 Use Delphi connectors made weather proof A good electrical system do not need to be disconected it will outlast everything else Quote Link to comment Share on other sites More sharing options...
