V8 Freak Posted November 12, 2006 Share Posted November 12, 2006 I've been toying with upgrading my fans.... (Currently unknown brand pulling from inside engine bay...) With bonnet closed on tickover today they took nearly 5 mins to drag the temp down to the point where they cut off again.... With the bonnet open, it was under 2 mins ! So, how can I sensibly move more heat from the engine bay ? Fan through the top of the bonnet? Some vents in the bonnet? Suggestions please.... I look forward to your views... Neil Quote Link to comment Share on other sites More sharing options...
Andy Posted November 12, 2006 Share Posted November 12, 2006 im sure ive seen extractor fans fitted to bonnets in the past. slimline ones designed for the job, not huge window ones before you ask. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 12, 2006 Author Share Posted November 12, 2006 I saw a picture of a slimline fan in a bonnet somewhere recently but I cannot for the life of me find it now I may need it ! Anyone seen the same pic ? (Bonnet either blue or grey !) Quote Link to comment Share on other sites More sharing options...
siearl Posted November 13, 2006 Share Posted November 13, 2006 I have a twin electric fan on the front of mine which is very good, will take some pics of it sometime today and post for you Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 13, 2006 Author Share Posted November 13, 2006 I have twin fans already installed but I fear a lot of heat remains trapped in the enging bay. I could upgrade the fans easily enough but it seems it could be easier to let the heat out... I look forward to seeing what you have.... And yay..... I found where I was before.... Any views on this ? http://www.pacet.co.uk/BONNET.HTM Neil Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 13, 2006 Share Posted November 13, 2006 HORRIBLE Looking ? Have a lookie at my cooling threads part 1 and part 2 .... and the side vents plus fans....makes a huge difference... Nige Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted November 13, 2006 Share Posted November 13, 2006 If you're really worried about the cooling do a swap with me, you'll have a TD that never overheats Quote Link to comment Share on other sites More sharing options...
Earl Posted November 13, 2006 Share Posted November 13, 2006 Thats just Like my 110 csw TDI can not get a lot of heat out of the heater in the winter Quote Link to comment Share on other sites More sharing options...
siearl Posted November 13, 2006 Share Posted November 13, 2006 Aide have you tried closing the window when you are driving Quote Link to comment Share on other sites More sharing options...
western Posted November 13, 2006 Share Posted November 13, 2006 Aide have you tried closing the window when you are driving Superb Si Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 13, 2006 Share Posted November 13, 2006 If you're really worried about the cooling do a swap with me, you'll have a TD that never overheats Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 13, 2006 Author Share Posted November 13, 2006 I done a little more looking around, a silly conversation with Nige (Hybrid from Hell) who easily demonstrated his knowledge of Land Rovers was better than I could ever dream of... (I recon he's got a blueprint memorised...) I think I'll try the side vent route he did for my first attempt at move hot air out of the bonnet area and then, if required, upgrade the no-name fans to some with muscle and pedigree... (If they exist ! LOL) I see the part numbers Nige.. Any clip numbers ? Neil Quote Link to comment Share on other sites More sharing options...
madcanuck Posted November 14, 2006 Share Posted November 14, 2006 Neil, I'm running two electric fans in front of the rad/sir con exchangerr on my V8, the fans are wired up to a manual dash sw, auto temp sw/rly system which great, I run in +45 C temps here in the middle east and have yet to experience and overheating problems!The only problems with the fans is RFI on the Stereo system, I'm currently re-wiring with sheilded wire to get rid of it. Cheers Tracy Quote Link to comment Share on other sites More sharing options...
western Posted November 14, 2006 Share Posted November 14, 2006 I done a little more looking around, a silly conversation with Nige (Hybrid from Hell) who easily demonstrated his knowledge of Land Rovers was better than I could ever dream of... (I recon he's got a blueprint memorised...)I think I'll try the side vent route he did for my first attempt at move hot air out of the bonnet area and then, if required, upgrade the no-name fans to some with muscle and pedigree... (If they exist ! LOL) I see the part numbers Nige.. Any clip numbers ? Neil I guess your going to use TD/Tdi air intake grilles, if so you might just need these numbers left [as on 200Tdi's] part number MWC2501 right [as on 300Tdi & Td5's] part number BTR6188 bush to hold grilles in place part number AFU1926L or use black countersunk headed screws to hold grilles to wing panel. or if you fancy a bit of shiney stainless steel to bling up your red 110 have a look here click 'what about us grilles' in the left sidebar. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 14, 2006 Author Share Posted November 14, 2006 I won't be needing the bling ! But thanks for thinking of my image... So.. It now begs the question.... Are you and eccentric millionaire who just surfs the net 24/7 looking for solutions for people on LR4X4 or do you have a sympathetic boss ?? Quote Link to comment Share on other sites More sharing options...
western Posted November 14, 2006 Share Posted November 14, 2006 (edited) I won't be needing the bling ! But thanks for thinking of my image...So.. It now begs the question.... Are you and eccentric millionaire who just surfs the net 24/7 looking for solutions for people on LR4X4 or do you have a sympathetic boss ?? eccentric millionaire I wish on my notebook at home, & only on -line evenings/weekends no internet access at work [too darn busy fixing aircraft Edited November 14, 2006 by western Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 14, 2006 Author Share Posted November 14, 2006 Nice job... I was at RAF Fairford for this years proceedings... Few shots here... http://proudto.servepics.com/thumbnails.ph...m=17&page=4 Still trying to find time to sift through the shots and put them online ! Also been to RAF Conningsby a few times. (Trip sponsored by Land Rover who supply the BBMF Land Rovers..) Last year they even let us into the Lancaster.. I have some great shots from most angles ! This year they took us around the Eurofighter (Typhoon) hanger and there were a number of areas the camera was banned... Open nose cones and cockpit... Quite an impressive plane though! Quote Link to comment Share on other sites More sharing options...
western Posted November 14, 2006 Share Posted November 14, 2006 You would have seen 4 of the Hawks as above doing their bit with 2 FRA Falcons for the flying display. the pic was taken while practising for last years Fairford's RIAT show Quote Link to comment Share on other sites More sharing options...
siearl Posted November 15, 2006 Share Posted November 15, 2006 A proper Aircraft Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 15, 2006 Author Share Posted November 15, 2006 Nooooooooooooooooooooooooooooooooooo !!!! This is a real aircraft..... One from my personal collection... Quote Link to comment Share on other sites More sharing options...
siearl Posted November 16, 2006 Share Posted November 16, 2006 Nah E3D get to see them all day every day and sometimes even the red arrows pop over for a visit. Quote Link to comment Share on other sites More sharing options...
Orange Posted November 17, 2006 Share Posted November 17, 2006 eccentric millionaire I wish on my notebook at home, & only on -line evenings/weekends no internet access at work [too darn busy fixing aircraft Is there one missing?? On a serious note - got any suggestions for the same problem in a RRC - 3.5 V8 too? Cheers Adrian Quote Link to comment Share on other sites More sharing options...
western Posted November 17, 2006 Share Posted November 17, 2006 Nope, only 4 in the part time team, it'll be the camera angle that makes it look as though one is missing. Quote Link to comment Share on other sites More sharing options...
