Ryan Posted November 14, 2006 Share Posted November 14, 2006 Ever since I fitted a pair of QT diff guards, I have been getting a deep-tone vibration on hard-ish acceleration. It appears to be coming from the back, and its like I was trying to accelerate in 3th when I should be in 1st (i'm not by the way ). The guard is not fouling on the rubber connector thingey, and I have not done anything else underneath apart from fitting a steering guard (though this was done the week before and I've only noticed the vibration since the QTs were fitted). Is this just a coincidence? Quote Link to comment Share on other sites More sharing options...
Andy Posted November 14, 2006 Share Posted November 14, 2006 i cant think why diffguards would cause that. take them off again & see if the vibration goes? Quote Link to comment Share on other sites More sharing options...
Ryan Posted November 15, 2006 Author Share Posted November 15, 2006 I was rather hoping I wouldn't have to take them off - I don't have a dry floor to lay on at the moment. Quote Link to comment Share on other sites More sharing options...
Andy Posted November 15, 2006 Share Posted November 15, 2006 yeah i know that problem with wet floors. unless they are catching the prop or the flange or something i cant see why they'd cause a vibration. could be worth getting someone to ride the clutch while you watch the props, if your bushes are gone (whos arent?) then i guess the axle might rotate enough for it to catch? Quote Link to comment Share on other sites More sharing options...
Ryan Posted November 26, 2006 Author Share Posted November 26, 2006 Just had a thought, I had to remove the anti-vibration thingy off the front axle, and did not refit it. Does it really do anything? Could this be my problem? Quote Link to comment Share on other sites More sharing options...
imspanners Posted November 26, 2006 Share Posted November 26, 2006 Did the rear guard have the spacer plate to stop the guard rubbing the rear prop-doughnut? Quote Link to comment Share on other sites More sharing options...
Andy Posted November 26, 2006 Share Posted November 26, 2006 dunno about the anti-vibration thing, would make sense that removing it causes vibrations...however i've known people take it off with no problems. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 27, 2006 Share Posted November 27, 2006 It's a harmonic damper, I doubt you would notice the difference with it not being there. Les. Quote Link to comment Share on other sites More sharing options...
Ryan Posted November 28, 2006 Author Share Posted November 28, 2006 Did the rear guard have the spacer plate to stop the guard rubbing the rear prop-doughnut? Yes it did. Quote Link to comment Share on other sites More sharing options...
LR90 Posted November 28, 2006 Share Posted November 28, 2006 It's a harmonic damper, I doubt you would notice the difference with it not being there.Les. But it might have been sufficient to damp a little tyre unbalance. Whichever way you look at it you're going to have to drop the prop, guard, swap wheels or something to try and isolate the problem Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted December 8, 2006 Share Posted December 8, 2006 If they're wraparound guards, wedge a little bit of wood or similar between the guard and the casing - I have these on a Ninety and they rattled like hell on certain road surfaces. Of course, I chose to ignore it and it seems that after a few heavy bashes offroad I've adjusted their natural resonant frequency... Quote Link to comment Share on other sites More sharing options...
Ryan Posted December 10, 2006 Author Share Posted December 10, 2006 If they're wraparound guards, wedge a little bit of wood or similar between the guard and the casing - I have these on a Ninety and they rattled like hell on certain road surfaces. Of course, I chose to ignore it and it seems that after a few heavy bashes offroad I've adjusted their natural resonant frequency... I don't think there is a problem there. The guards are well and truely glued to the diff case, theres no gaps at all. Its definitely not a rattle. I think I'll try and find a replacement harmonic damper (as I foolishly threw mine away) to bolt on and see if that solves the problem. Quote Link to comment Share on other sites More sharing options...
Ivan Posted December 11, 2006 Share Posted December 11, 2006 Don't bother with a harmonic damper it does nothing. I took mine off years ago when I fitted a QT diff guard and I have not noticed any change. If you can get one for free then give it a go but I wouldn't pay money for one. HTH Ivan Quote Link to comment Share on other sites More sharing options...
Ryan Posted December 12, 2006 Author Share Posted December 12, 2006 Anyone in the Southampton area have a harmonic damper kicking around that they don't want/need? Pretty please... Ryan Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 12, 2006 Share Posted December 12, 2006 Anyone in the Southampton area have a harmonic damper kicking around that they don't want/need? Pretty please...Ryan you can't fit the damper without removing the guard anyway i'm in bitterne don't have a damper but willing to have a look see what we can find if you want mike Quote Link to comment Share on other sites More sharing options...
moose Posted December 13, 2006 Share Posted December 13, 2006 Anyone in the Southampton area have a harmonic damper kicking around that they don't want/need? Pretty please...Ryan Ryan, I might have one kicking about in the garage (and iam in southampton) i will take a look for you. But really dont think that its the cause of your problems. I took mine off before offroading took it off for me My mates three door 200's dont have them and old range rovers that i have played with also didnt have them... tho the new ranger rover sport does have them (two one each side above the tail pipes exits on the rear bumper) Quote Link to comment Share on other sites More sharing options...
