wanger Posted October 18, 2015 Share Posted October 18, 2015 I can confirm that from a 1985 2.5NAD 110 to a 2013 tdci 110 chassis the dimensions from hockey stick to TB bracket are the same. So IF the TB moves it must be on different mounts. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted October 18, 2015 Share Posted October 18, 2015 Bear in mind there are atleast two different type of gearbox/t-box mounts they may mount in the same place on the chassis but I can guarantee the t-box is not in the same place as there are atleast three different front prop lengths all rover front axle and lt230 t-box. Mike Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 18, 2015 Author Share Posted October 18, 2015 They're different mounts then! Quote Link to comment Share on other sites More sharing options...
Lewis Posted October 18, 2015 Share Posted October 18, 2015 Yes, didn't we go through all this in a recent thread? Transfer box on 4cyl models up to end of 200tdi is in the same location - slightly further back than 300tdi onwards Thread here http://forums.lr4x4.com/index.php?showtopic=95716&view=&hl=&fromsearch=1 Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 18, 2015 Share Posted October 18, 2015 I believe V8 models had the 'slightly further forward' transfer box position too, which the 4-cyl models adopted when the 300Tdi came in in the mid nineties. Quote Link to comment Share on other sites More sharing options...
Lewis Posted October 18, 2015 Share Posted October 18, 2015 I'm not convinced on that james, my mates 90 was 3.5 hp22 lt230, then 3.9 r380 lt230, now disco 200tdi disco lt77 and lt230, all were with the transfer box in the upto end of 200tdi location, props remain unchanged. Had the transfer box been further forward (as per 300tdi) the sticks wouldn't have fitted through the tunnel surely? And there wasn't a fat lot of room in front of the water pump before the rad for the whole lot to go any closer to the front crossmember Edit, now I think about it it's got the 4cyl tunnel and floor plates fitted, so does that tell us anything? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 18, 2015 Share Posted October 18, 2015 Not sure, all a bit of a mystery. My knowledge only extends to factory vehicles. I think a 300Tdi front propshaft is about 635mm long. And a 2.5TD/200Tdi one is about 685mm. So the 300Tdi (and if I'm right the V8) transfer box must be about 50mm closer to the front axle. Isn't that why the tunnel shape changed, with that strange side bulge out on the right - to give clearance for the front output housing of the transfer box? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 18, 2015 Share Posted October 18, 2015 This post from miketomcat seems to confirm my thoughts. The numbers are slightly different as I assume the measurements were taken in a different way but it seems to suggest that 300Tdi and Td5 vehicles used the same transfer box position relative to the axles as the earlier V8 did. http://forums.lr4x4.com/index.php?showtopic=87209&p=752861 Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 23, 2015 Share Posted October 23, 2015 I believe they sit slightly nose-up on the Tdci models? Only problems I can think of at the moment would be possible oil starvation to the front output bearings and propshaft angles perhaps needing a slight tweak. The oil gets whipped up into a mist when driving, so the bearings will be well lubricated. Quote Link to comment Share on other sites More sharing options...
