ejparrott Posted January 10, 2016 Share Posted January 10, 2016 Gearing up for the 88's rebuild (finally!!!) What's the thinking on engine mounts at present? Currently got very knackered Series square mounts, probably diesel spec. Mikey's put me on to Glencoyne's offerings, supposedly soft but they need trimming to fit, what do we think? Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted January 11, 2016 Share Posted January 11, 2016 I fitted them and they were no different to the normal petrol ninety mounts that I took off. They were not expensive though and they stop the engine falling out but next time I'll just put normal mounts in. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 11, 2016 Share Posted January 11, 2016 I think that was the rub, most aftermarket stuff is so hard it rattles the chassis to bits, Glencoyne mounts are supposedly more forgiving. Quote Link to comment Share on other sites More sharing options...
Serious Series Posted January 11, 2016 Share Posted January 11, 2016 Fitted Glencoyne ones to my 2.5N/A engine did make a differene for me , thay are now under my 200DI discovery engine. Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted January 11, 2016 Share Posted January 11, 2016 I think that was the rub, most aftermarket stuff is so hard it rattles the chassis to bits, Glencoyne mounts are supposedly more forgiving. on a deflection test they were pretty much identical, so similar in fact even down to the mould flash... ( STC434 ) was what I tested against - thats what I used on my 90 when it was a 4 cyl petrol and eventually a V8 on an adapter kit. Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 11, 2016 Share Posted January 11, 2016 The mounts sold by Richard are 2.5 spec, petrol, diesel and Defender 200 Tdi. They are manufactured by Bearmach and when I used them, were softer than Gen Parts (which caused terrible cab vibration). The square type are SIII diesel mounts, Series petrol mounts are circular but smaller in diameter to these 2.5 mounts. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted January 11, 2016 Author Share Posted January 11, 2016 Not much trimming then by the looks of your pictures SS? They seemed a touch on the expensive side when I looked at the website, then I got the parts book out and had a flick through and they did appear to be similar to various others in the book, going on shape alone of course. Quote Link to comment Share on other sites More sharing options...
Serious Series Posted January 11, 2016 Share Posted January 11, 2016 Glencoyne has done some good modifications , based on his reputation I choose to buy them from him. I had already bought some same design from ebay they where way harder rubber. Quote Link to comment Share on other sites More sharing options...
Pollywog Posted January 11, 2016 Share Posted January 11, 2016 I went with the 'genuine parts' mounts from Paddocks and yes they came in blue bags but they have been perfectly fine and I'm very happy with them. I didn't need to trim off as much as shown above I just scalloped the top edge slightly. The biggest change to vibration levels came with changing the gearbox mounts to the same type as the engine. Those mounts I bought loose from a show but I think they are allmakes. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 11, 2016 Share Posted January 11, 2016 I've seen other aftermarket ones that have proved very hard too. Quote Link to comment Share on other sites More sharing options...
