Mark Posted November 23, 2006 Share Posted November 23, 2006 OK, I know very little about V8's, but I have been talking with my brother about the possibility of changing the tired, and terrible sounding 3.5EFI in his rangie. We have seen a couple of carbed V8's and wondered what you needed to do to turn one into an EFI one, given that we have all the EFI stuff already there? So, how hard is it? Is is just a case of swapping the carb inlet manifold for the plenum chamber off the old EFI or are there a whole raft of other small things that also need changing? NB. I have already repeatedly shouted that he should fit a nice 200TDI at him, but to no avail... Cheers Mark Quote Link to comment Share on other sites More sharing options...
GBMUD Posted November 23, 2006 Share Posted November 23, 2006 EFi has a different cam too IIRC. Chris Quote Link to comment Share on other sites More sharing options...
roguevogue Posted November 23, 2006 Share Posted November 23, 2006 Swapping the block should be a direct replacement, you will need to change the front cover/timing cover, but you will need to have this off for a new timing chain and gears anyway. I stand by to be corrected, the worm can't be far away. Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted November 23, 2006 Share Posted November 23, 2006 EFI cylinder heads have cut outs for the injectors, best to try and find a complete 3.5 EFi for direct replacement. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 25, 2006 Share Posted November 25, 2006 The cutouts are TINY, with a bit of care/cleanliness and a dremel you could replicate them, or just swap the heads over onto the new block if you think they're OK. TBH I doubt the cutouts would make a major difference if you didn't bother - the gaskets intrude more than the port edges anyway and any new gasket should have the cutout in it. As has been said - swap the inlet manifold / loom onto the new block and away you go. Wasn't aware timing covers needed to be changed(?) but stand to be corrected. Quote Link to comment Share on other sites More sharing options...
Jon White Posted November 25, 2006 Share Posted November 25, 2006 Really? Well my 3.5 on carbs has an ex 3.9 efi front cover on it and I didnt notice any difference at all (had to smash the origional to remove it due to siezed bolts) Jon Quote Link to comment Share on other sites More sharing options...
HoSS Posted November 26, 2006 Share Posted November 26, 2006 There are multiple threads on this forum for the Carb->EFi conversion. Including mine which contains a load of good info. http://forums.lr4x4.com/index.php?showtopic=7010&hl= Quote Link to comment Share on other sites More sharing options...
V8RRC Posted November 27, 2006 Share Posted November 27, 2006 There are multiple threads on this forum for the Carb->EFi conversion.Including mine which contains a load of good info. http://forums.lr4x4.com/index.php?showtopic=7010&hl= Hoss, Unless I missed that bit when I read through what did you do regarding the cutouts in the heads? Quote Link to comment Share on other sites More sharing options...
HoSS Posted November 27, 2006 Share Posted November 27, 2006 Hoss,Unless I missed that bit when I read through what did you do regarding the cutouts in the heads? despite being carbs from new, my heads had cut-outs already. also some people say it doesnt matter if you dont have them anyway. Quote Link to comment Share on other sites More sharing options...
V8RRC Posted November 27, 2006 Share Posted November 27, 2006 Ahh I see Just wondering as my old engine would want a lot of work to put it right & that has cutouts! But I have a new army re-con that has done about 600 miles since being re-built but no cutouts & that is the one I would want to swap to EFi & M/S Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 28, 2006 Share Posted November 28, 2006 Just do it - if you're worried about the cutouts get the dremel and vacuum cleaner out and add them just don't drop debris down the inlets! Quote Link to comment Share on other sites More sharing options...
