door cards for ex mod 110
They did fit black plastic trims to Wolf door bottoms, though, I think,similar to those on the NAS 90s.  The new canvas door pockets from Exmoor Trim look pretty good, and though not cheap, are probably comparable to the plastic cards.  I'd go for the green canvas over the sand just because it'll hide shoe marks more easily.  With a sheet of aluminium behind, they'd be practical, tidy and you'd have good protection of the door from errant boots.
Made my own from 6mm marine ply, only need the lower portion as this is where you feel the cold. I stapled some foil backed plastic insulation on the rear and cut out some speaker rings cut from 2 thicknesses of 18mm ply to allow door speakers to be fitted, all this comes off and doesn't detract from the base vehicle in use. i.e chopping into the lower dash or panels.
Add a splash of nato green paint and you are good to go.
I used plywood and covered it in nylon carpet simply as a way of mounting speakers for the radio, it's a bit Heath Robinson but they work ok and cost nothing. The inner side of the door has been covered in Flashband also.
If I was doing it again then would probably cut some chequer and fix that because the carpet is a pain to clean after off-roading.
