mcc1979ian Posted December 5, 2016 Share Posted December 5, 2016 Evening all, just wondering if anyone might know of a reason why my 300tdi might stink of diesel fumes all the time. i get alot of white smoke when shes started from cold but once its warm this dies down but when its running its always got a very strong smell o diesel reek Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 5, 2016 Share Posted December 5, 2016 Spill pipes? When ours start smelling it's usually a split or perished Spill hose. Mike Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted December 5, 2016 Author Share Posted December 5, 2016 You mean the return hose to the tank? Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 6, 2016 Share Posted December 6, 2016 The spill pipes are the black braided hoses between the injectors and are very prone to splitting. You cab buy rolls of the hose from Halfords far cheaper than LR - LR will sell the whole assembly for a small fortune but all you need is the 4mm fuel hose. 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 6, 2016 Share Posted December 6, 2016 The halfords stuff only seams to last a year or so. Mike Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 6, 2016 Share Posted December 6, 2016 Surely you must be able to get silicon, or something like it that I'll last a lifetime now? Neoprene maybe? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 6, 2016 Share Posted December 6, 2016 I suspect that Halfords silicone pipe is designed for vacuum/boost not fuel. Small bore fuel pipe should do it, or push-fit nylon. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted December 6, 2016 Share Posted December 6, 2016 Might be worth checking the tank filler neck if there is a constant smell and it's not the return pipes - mine had developed a pinhole, which araldite sealed. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 6, 2016 Share Posted December 6, 2016 Silicone and diesel don't get on very well at all. Mike Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted December 6, 2016 Author Share Posted December 6, 2016 Will replace the pipes between injectors first. the rest of the engines been a nightmare so their probably shot too. The fuel tank had all new gaskets and pipes when i fitted the engine so should be ok. Quote Link to comment Share on other sites More sharing options...
hangover Posted December 19, 2016 Share Posted December 19, 2016 i think i used 1/8th inch fuel hose on mine, tight fit but wont ever come off. Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 19, 2016 Share Posted December 19, 2016 On 06/12/2016 at 11:01 AM, miketomcat said: The halfords stuff only seams to last a year or so. Mike So too the LR stuff - I made the mistake of buying their replacement, complete with the unions, for a lot of money, and 18 months later the hoses were split again. Far better to buy the cheap hose on the roll than the Gen Parts replacement. If you can find decent hose on the roll, then so much the better. Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 19, 2016 Share Posted December 19, 2016 2 hours ago, hangover said: i think i used 1/8th inch fuel hose on mine, tight fit but wont ever come off. The stretch is likely to tear or split the hose even quicker. Quote Link to comment Share on other sites More sharing options...
hangover Posted December 20, 2016 Share Posted December 20, 2016 19 hours ago, Snagger said: The stretch is likely to tear or split the hose even quicker. Not that tight, and i doubt it will do anything to the reinforced hose. Quote Link to comment Share on other sites More sharing options...
