Paul Humphreys Posted May 15, 2010 Share Posted May 15, 2010 Well started off as "just a new metal bumber" now it is a lot more!! So it has turned into a rear bumper with winch mount, just need to make the winch mounting plate. I will also be adding a swing away wheel carrier at a later date. Thanks go out to Gary Paul Quote Link to comment Share on other sites More sharing options...
garymorris Posted May 15, 2010 Share Posted May 15, 2010 Don't mention it Do you think it will be too flimsy ? Gary Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted May 15, 2010 Author Share Posted May 15, 2010 Don't mention it Do you think it will be too flimsy ? Gary I think it will be up to the same standard as the rest of the LC Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 15, 2010 Share Posted May 15, 2010 I think it will be up to the same standard as the rest of the LC Bit lardy Looks good, did you think about making it a little higher up? or would you run into clearance issues with the tailgate? Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted May 15, 2010 Author Share Posted May 15, 2010 Bit lardy Looks good, did you think about making it a little higher up? or would you run into clearance issues with the tailgate? Yes, the bottom tail gate drops down, so it might have been a problem. It is a little closer in than standard. It is not as tall. Paul Quote Link to comment Share on other sites More sharing options...
garymorris Posted May 29, 2010 Share Posted May 29, 2010 Got any paint on it yet ? I bet south wales was wet today Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted August 22, 2010 Author Share Posted August 22, 2010 Pictures, the number plate light is a temp untill I get the ones I want. Thanks again to Gary. Paul Quote Link to comment Share on other sites More sharing options...
landrover598 Posted August 22, 2010 Share Posted August 22, 2010 Looks very smart Paul, one sugestion i would make, is that don't rely on the gas strut to be the stop for how far it can swing open, as a bit of steel / teather wire. I've got a gas strut on my defender rear door, and if your not carefull, the momentum of the weight of the door opening (especially when parked on a side slope) can and has snapped the end clean off the strut . Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted August 22, 2010 Author Share Posted August 22, 2010 I do have a plan for a bit of cable and a second catch for holding it closed, just incase the one comes undone. Paul Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 22, 2010 Share Posted August 22, 2010 Does it sit lower than a standard one Paul? Just wondering what it's fine to your departure angle. Certainly very solid looking! Quote Link to comment Share on other sites More sharing options...
jonost24 Posted August 22, 2010 Share Posted August 22, 2010 Nice idea with the toggle clamp Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted August 22, 2010 Author Share Posted August 22, 2010 Does it sit lower than a standard one Paul? Just wondering what it's fine to your departure angle. Certainly very solid looking! It is a bit better than standard and yes it is very strong. My mate with another 80 series drove into the back of me. Just marked the paint, wrote off his front bumper and dented the wing and lower pannel!! It also takes the weight of the LC when doing the bome hole on Strada Paul Quote Link to comment Share on other sites More sharing options...
garymorris Posted August 22, 2010 Share Posted August 22, 2010 Don't mention it one good turn deserves another as they say I thought you might have had your paint brush out given the good weather Gary Quote Link to comment Share on other sites More sharing options...
Scruffyhippo Posted August 22, 2010 Share Posted August 22, 2010 Given me a few ideas for a disco bumper Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 23, 2010 Share Posted August 23, 2010 Looks nicely thought out. One question - why did you put the spare smack in the middle? Don't you like seeing behind you...? Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted August 24, 2010 Author Share Posted August 24, 2010 Looks nicely thought out. One question - why did you put the spare smack in the middle? Don't you like seeing behind you...? First off I would have to move the fog light if it was to one side, the second is I am a lorry driver and never use the middle miirrow anyway Paul Quote Link to comment Share on other sites More sharing options...
HPLP Posted August 24, 2010 Share Posted August 24, 2010 Hey Paul Where did you get the toggle clamp from? Ive been trying to track down one or two for my spare wheel carrier. Thanks, h Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted August 24, 2010 Author Share Posted August 24, 2010 It came from http://wdsltd.co.uk/ Paul Quote Link to comment Share on other sites More sharing options...
laurynas Posted September 3, 2019 Share Posted September 3, 2019 On 8/24/2010 at 8:51 PM, HPLP said: Hey Paul Where did you get the toggle clamp from? Ive been trying to track down one or two for my spare wheel carrier. Thanks, h Hey HPLP, I know my post is too late, but I would also suggest to look to quick release toggle latches. Came across these- would look nice in black: https://www.ojopsweden.com/product-tag/military-latches/ Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 12, 2019 Share Posted November 12, 2019 A bit late? 9 years late Quote Link to comment Share on other sites More sharing options...
