jordan_meakin Posted October 11, 2017 Share Posted October 11, 2017 I am hopefully replacing this at the weekend providing I can get the crown nut off. I'm sure there are intricate details of setting various blah blah blah but, is there a specific torque for that nut when refitting? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 12, 2017 Share Posted October 12, 2017 What vehicle and what variant of axle/diff? Quote Link to comment Share on other sites More sharing options...
jordan_meakin Posted October 12, 2017 Author Share Posted October 12, 2017 Series 3 Rover diff. Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted October 13, 2017 Share Posted October 13, 2017 85 lb ft. You only need to remove the flange then lever the seal out and replace. No other dismantling needed - even on the early axles with the alloy housing bolted on. Quote Link to comment Share on other sites More sharing options...
jordan_meakin Posted October 13, 2017 Author Share Posted October 13, 2017 Ooo thanks. Fingers crossed it comes out nice and easy!! Quote Link to comment Share on other sites More sharing options...
Jon W Posted October 14, 2017 Share Posted October 14, 2017 If you are struggling to get the seal out, screw a self tapping screw into it and lever out with a claw hammer. Just make sure you have the right replacement seal 1st before making a mess Quote Link to comment Share on other sites More sharing options...
jordan_meakin Posted October 14, 2017 Author Share Posted October 14, 2017 Well, no luck. Couldn't get the sodding crown nut off. Firstly, someone had kindly tried before but failed to remove the split pin, leaving it stuck in with nothing to get hold of to pull it out. Great. Any ideas? I'm thinking it'll need cutting off but it's bloody awkward round there for a grinder. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 14, 2017 Share Posted October 14, 2017 Impact gun... Quote Link to comment Share on other sites More sharing options...
jordan_meakin Posted October 14, 2017 Author Share Posted October 14, 2017 Don't have one... Quote Link to comment Share on other sites More sharing options...
simonb Posted October 14, 2017 Share Posted October 14, 2017 Drill out the split pin, its only soft metal. If the nut is still stuck, use a jack under the spanner to take up the slack in the diff ( with the wheels chocked or the brake pedal wedged down) and then belt the spanner with a lump hammer - works every time. Quote Link to comment Share on other sites More sharing options...
