Simon_CSK Posted January 21, 2018 Share Posted January 21, 2018 Is it possible to reprogram a remote fob for a Disco 2? I have a spare from another car and need it for my current car. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted January 21, 2018 Share Posted January 21, 2018 Not with Testbook,unless you have the original barcodes for the fob. But Nanocom will happily do it from the code inside the fob on the little piece of paper stuck to the circuit board. Five characters long from memory... Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted January 22, 2018 Share Posted January 22, 2018 I did mine with my Nanocom using the code on the sticker. 6 digits, if I recall. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted January 22, 2018 Share Posted January 22, 2018 Lynx instructions seems to imply that you can do it without any numbers - you just have the ignition on and the lynx thing in the correct mode and press the keyfob (each of them) (16 times?)... There is a video showing it being done for a defender but they say it works for other cars too... It would be nice if anyone can confirm thatt this works for the Discovery 2 though... Quote Link to comment Share on other sites More sharing options...
sierrafery Posted January 22, 2018 Share Posted January 22, 2018 14 hours ago, Ally V8 said: Not with Testbook,unless you have the original barcodes for the fob. But Nanocom will happily do it from the code inside the fob on the little piece of paper stuck to the circuit board. Five characters long from memory... There are cases when the conversion table works as to convert the short code into the long one, it didnt work for me with hawkeye but i've seen posts where it was confirmed to work, worth a try if nanocom is not available this one disco2_fobcode_2_Barcode.xlsx Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted January 22, 2018 Share Posted January 22, 2018 2 hours ago, sierrafery said: There are cases when the conversion table works as to convert the short code into the long one, it didnt work for me with hawkeye but i've seen posts where it was confirmed to work, worth a try if nanocom is not available this one disco2_fobcode_2_Barcode.xlsx Yes, I tried that, didn't work ! Seems not many Testbooks around now,the main dealer close to me has one that doesn't work. Much more likely to be Nanocom's or similar available. Quote Link to comment Share on other sites More sharing options...
bear Posted January 22, 2018 Share Posted January 22, 2018 (edited) Hi Simon, If you put your rough location in your profile there may be someone near you with the necessary equipment. I have a Nanocom Evo Griff Edited January 22, 2018 by bear Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted January 22, 2018 Author Share Posted January 22, 2018 5 hours ago, bear said: Hi Simon, If you put your rough location in your profile there may be someone near you with the necessary equipment. I have a Nanocom Evo Griff Griff I am in Ayrshire and know we are a little thin on the ground up here. I have Hawkeye for my P38 so could upgrade it forthe D2 if I knew it would work. Quote Link to comment Share on other sites More sharing options...
Casinoguy1 Posted February 17, 2018 Share Posted February 17, 2018 On 1/21/2018 at 6:47 PM, Simon_CSK said: Is it possible to reprogram a remote fob for a Disco 2? I have a spare from another car and need it for my current car. I have just joined and have the same issue if you got a response to this please let me know, I am also looking to buy a tool which will read and reset all the discl 1+2 bits and pieces inc dash ABS etc. Quote Link to comment Share on other sites More sharing options...
bear Posted February 18, 2018 Share Posted February 18, 2018 16 hours ago, Casinoguy1 said: I have just joined and have the same issue if you got a response to this please let me know, I am also looking to buy a tool which will read and reset all the discl 1+2 bits and pieces inc dash ABS etc. Hi, As mentioned to Simon, if you put your location in your profile then there may be someone near you with the kit. It is easy to add a key with Nanocom Evo. Griff Quote Link to comment Share on other sites More sharing options...
Casinoguy1 Posted February 18, 2018 Share Posted February 18, 2018 9 hours ago, bear said: Hi, As mentioned to Simon, if you put your location in your profile then there may be someone near you with the kit. It is easy to add a key with Nanocom Evo. Griff Not letting me modify profile at the moment, I am in Amersham Bucks. Thanks for the info Quote Link to comment Share on other sites More sharing options...
