Chubby M Posted February 12, 2019 Share Posted February 12, 2019 Hi, good afternoon. Question re front axle springs on a 110 (1984). I have inherited LR springs for the front axle (look to have been fitted 5 to 8 years ago with when new bulkhead etc. was fitted). They are standard length and look to be standard load. The longer one (by 10mm) is banded with white paint, the shorter with yellow banding. I've checked the archives etc. but could someone tell me which one is driver side please? Huge thanks again chaps. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 12, 2019 Share Posted February 12, 2019 Long ones on the left side to counteract the offset position of the engine. Quote Link to comment Share on other sites More sharing options...
paime Posted February 12, 2019 Share Posted February 12, 2019 8 minutes ago, Red90 said: Long ones on the left side to counteract the offset position of the engine. I'm going to throw a spanner in the works here and say the long ones are on the driver's side (right hand side). Could be a UK/Canada difference though? Also, i could be totally wrong! Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 12, 2019 Share Posted February 12, 2019 (edited) I have a rhd vehicle and the white spring is on the right (driver) and yellow on the left. The reason for my decision is in my thread - page 5 However Red’s comment has me thinking, as the engine position doesn’t move rhd to lhd. Edited February 12, 2019 by Peaklander Added link Quote Link to comment Share on other sites More sharing options...
western Posted February 12, 2019 Share Posted February 12, 2019 Longer spring on drivers side, doesn't matter if the vehicle is left or right hand drive. REASON - - - when driver is onboard vehicle will drive & sit level. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 12, 2019 Share Posted February 12, 2019 If you put the longer spring on the right, you will have a tilted truck. The engine and gearbox are offset to the left. If you are heavier than the engine and don't have passengers, you might offset the tilt...... IMO, a better solution for a fat owner with a RHD truck is to use the same springs on both sides. Going long on the right is way too much. Quote Link to comment Share on other sites More sharing options...
neil110 Posted February 12, 2019 Share Posted February 12, 2019 In the parts list the springs are described as driver side and passenger side Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 12, 2019 Share Posted February 12, 2019 56 minutes ago, neil110 said: In the parts list the springs are described as driver side and passenger side Yes, I know..... But if you follow that advice on a RHD, you will have a bad tilt. RHD Defenders are best with even springs side to side. LHD need different springs as they are more unbalanced. as everything is on the left. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 12, 2019 Share Posted February 12, 2019 My final decision was based on advice from @Retroanaconda who said, it's negligible but if it tilts, then swap them. It seems to be negligible - I can't see the difference. Edit: 78Kg in case anyone's wondering 😀 Quote Link to comment Share on other sites More sharing options...
Chubby M Posted February 13, 2019 Author Share Posted February 13, 2019 Gents, as always many thanks. Very helpful. Quote Link to comment Share on other sites More sharing options...
neil110 Posted February 13, 2019 Share Posted February 13, 2019 (edited) It is worth noting that in recent years Land Rover have stopped doing handed springs for the rear of the vehicle. Yet they have retained handed front springs. Whilst the engine and gearbox are offset to the left, the bulk of the transfer box and prop shafts are on the right hand side. Edited February 13, 2019 by neil110 Quote Link to comment Share on other sites More sharing options...
