Mo Murphy Posted June 12, 2019 Share Posted June 12, 2019 Does anyone know of a reliable source of these that a) fit in a standard lamp (not too long) and b) illuminate appropriately ie. Dim on side bright on brake. Cheers Mo Quote Link to comment Share on other sites More sharing options...
Arjan Posted June 12, 2019 Share Posted June 12, 2019 We used Chineese ones for a while that did OK but have now changed to full LED units. Being waterproof is a big plus... Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted June 12, 2019 Share Posted June 12, 2019 Ta Da! https://www.paddockspares.com/red-stop-tail-lamp-led.html Steve 😃 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 12, 2019 Author Share Posted June 12, 2019 I want the bulbs for my drl project using clear stop and tail lamps in place of my side lights. Nakatanenga sell Drl LED side lights but at 70 quid each. Mo Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 12, 2019 Share Posted June 12, 2019 Because of the way an LED works, I don't think you'll find a white LED version of a stop/tail. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 12, 2019 Author Share Posted June 12, 2019 Why Ross, are LED bulbs racist ? 😉 sorted now, good old Halfrauds. Please don't post, anyone, how LED bulbs are illegal etc. I've read it a million times ! But I do have DRLs now. Thanks for your help. Mo 1 Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 13, 2019 Share Posted June 13, 2019 20 hours ago, landroversforever said: Because of the way an LED works, I don't think you'll find a white LED version of a stop/tail. LEDs can come in many colours, as well as white white with varying intensities is not unusual. In theory I see no reason why you could not have a white emitter with 2 circuits of different brightness.However what products someone has chosen to manufacture for generic automotive use may be more limited. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 13, 2019 Share Posted June 13, 2019 On 6/12/2019 at 4:34 PM, steve200TDi said: Ta Da! https://www.paddockspares.com/red-stop-tail-lamp-led.html Steve 😃 I have the wypac full set, brilliant were on my 90 then I sold that and put them on my 110 I have just rewired the 110 and put back on with plugs can’t fault them Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 13, 2019 Author Share Posted June 13, 2019 I don't doubt it, I've used Perei NAS rear lights on mine. I tried the Wipac NAS rear light but found it too directional and I didn't like being able to see the individual LEDs. The Perei lights are more expensive but the gem diffuses the light to make it less directional. Mo Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 13, 2019 Share Posted June 13, 2019 27 minutes ago, Mo Murphy said: I don't doubt it, I've used Perei NAS rear lights on mine. I tried the Wipac NAS rear light but found it too directional and I didn't like being able to see the individual LEDs. The Perei lights are more expensive but the gem diffuses the light to make it less directional. Mo I think this every time I look at front of 110 with side lights on they are a directional light where as original lights were all over front wing Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 13, 2019 Share Posted June 13, 2019 4 hours ago, mickeyw said: LEDs can come in many colours, as well as white white with varying intensities is not unusual. In theory I see no reason why you could not have a white emitter with 2 circuits of different brightness.However what products someone has chosen to manufacture for generic automotive use may be more limited. It's all doable, but my understanding is that LEDs can't be filtered in the same way light from an incandescent lamp can be. So in the case of a stop/tail LED in white, you would not get a very good output if you then put that behind a red lense. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 13, 2019 Author Share Posted June 13, 2019 2 minutes ago, landroversforever said: It's all doable, but my understanding is that LEDs can't be filtered in the same way light from an incandescent lamp can be. So in the case of a stop/tail LED in white, you would not get a very good output if you then put that behind a red lense. Good job they're going behind a clear lens then Ross 😉👍 Mo 2 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 13, 2019 Author Share Posted June 13, 2019 I'm not a fan, though, of the cold blue white bulb, it doesn't really go with the 90's incandescent headlamps. I wonder if warm white are available ? Mo Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 19, 2019 Share Posted June 19, 2019 On 6/13/2019 at 10:32 PM, Mo Murphy said: I'm not a fan, though, of the cold blue white bulb, it doesn't really go with the 90's incandescent headlamps. I wonder if warm white are available ? Mo I have seen them online. Quote Link to comment Share on other sites More sharing options...
